ProLoL
- Jan 13, 2017
One group for each channel.
My friend used to have a m-dac. He now has my old Master-7. For him, it's not comparable. The r2r-11 is not so far behind so you should like it if you value an analog sound, tonal accuracy and a flat response.
No, what i mean't was the Master-7 has a clear edge over the m-dac. The r2r-11 is closer to it than the m-dac.Dear FreadA,
You mean the M-Dac is better overall but the R2R 11 is more analog like so it might suit better someone's preference?
My system is very flat and transparent BTW.
You mean the new limited edition one?I own 1 NFB11.38 it sound great what is your question
What headphones are you using? Also what source are you feeding it with?Received my NFB-11.38!
I'm so not used to desktop dac/amp. By turning the volume dial just a little, its already quite loud. I can't even reach the 10-2 sweet spot!
Maybe you can turn down the source volume?
I think what you want to do is leave the Foobar volume at full and turn down the overall Windows volume (or whatever operating system you are using). I believe that when I first installed the Amanero drivers, the volume was set to 100 in Windows. I normally run it at around 70-80.Update 2: So something chimed on my desktop. Its still at 100% loudness. Now my eardrums are blown off.
Run via asio and bypass windows mixer volume.
The Meze are so sensitive. Not surprised.L or H gain?
