Pricklely Peete
Franken modder
- Feb 17, 2008
Pricklely Peete, I notice you own the LD MK lll, how would you describe it in comparison to the Audio-GD C-2C?
My LD MKIII has been DIY modified rather extensively so the comparison won't resemble a stock vs stock opinion. My LD MKIII when used with cans over 100 ohms in impedance is quite lively and yet not nearly as detailed or refined (even with the mods I performed which elevated the MKIII by a fair margin) as the C-2C (with stepped vol pot). The C-2C has a slight tube like quality to it but has the power and grip of a well designed SS amp controlling the headphone drivers like an iron fist. The sound signature of the C-2C is a little bit warm with a thicker bottom end than the MK III (despite using 6H30pi-DR power tubes). All in all the MK III for it's price is not a bad entry level tube amp with either amp rewarding you with a decent experience. I feel the C-2C scales better with source improvements whereas the MK III hits a wall much sooner.
Also.......
The MK III is average in terms of power output levels with the C-2C almost putting out 10X more (depending on the impedance of the load) giving the C-2C a ton of clean dynamic headroom (an important factor in keeping transient peaks from compression artifacts even at moderate vol levels). I listen to the FUN/C-2C combo most of the time when I'm on the computer and sub the Mk III in every once in a while to taste it's fruit so to speak. I enjoy both amps, however you will never confuse the two in a blind test. The C-2C is far more sophisticated in it's overall presentation than the MK III and so it should be IMO because it's roughly 40% more in price (vs the stock trim MK III). One thing I need to mention about the Mk III, the stock driver tubes in the MK III must be replaced if you expect to get anywhere near it's true potential. Sure the GE 6AK5's are alright but better low cost NOS tubes make a world of difference with this little amp. I use Sylvania black plate round getter (WA/WB mil spec) with the 6H30Pi-DR's. I hope that helped you out some
![smile.gif](http://files.head-fi.org/images/smilies/smile.gif)
Peete.
