fredrikj
- Aug 4, 2012
Hi fredikj,
Had thought of trying an Audiobyte Z as a possible step up from my Audio-GD DI-2014 I2S to my M7. But thought I needed to get another DIY I2S board from Kingwas to make the Audiobyte Z match.
I thought the Audio-GD I2S input board that I DIY fitted to my M7 had a different HDMI 'pin in' to the Audiobyte Z HDMI out ?. I recal Audio-GD/Kingwa stating somewhere that his board was set to match the OffRamp 5.
Maybe I got the wrong
Frizzup
Yes, that was my thought as well; upgrading from my DI-2014 to get away from USB32. I hoped that Audio-GD would have a better USB32 driver over time, but I'm giving up on Audio-GD USB. I'm sure it sounds good, but together with Jplay the driver is just bad. I confirmed the pin-out of the Hydra Z with Audiobyte before I got it. As I have understood it both Hydra Z and OR5 can use a straight through standard HDMI cable, while PS Audio and Pink Faun's I2S PCIe bridge will work, but they have swapped the left/right channel. With Pink Faun, they can fix this on the board. My Pink Faun card is back at Pink Faun for modification from TTL to LVDS and swapping left/right...
-Fredrik
