RAZRr1275
- Nov 22, 2011
@RAZRr1275 Maybe go halfway into the warmth scale and see if you perceive a difference after an hour of listening.
IPS0 On would give you 2x oversampling without monkeying with stopband attenuation at all.
Or you could go nuts and just put jumpers on both IPS and ATT pins to go with non-oversampling and minimum stopband attenuation.
If your system doesn't give the Master-11 a clean enough signal, you might get channel imbalance going NOS. That's why the NOS settings aren't even shown on the Audio-GD site at all. It's an advanced setting that isn't for the faint of heart.
But I compiled all of the info I could on this page: http://www.basshead.club/audio-gear/master-11-info/
Sounds good! I'll give it a go tomorrow. 15 mins or so enough for everything to discharge? I guess what I mean is say I try one setting, and want to try something else, I shut it off and open it up again -- how long before I can start monkeying around without running the risk of getting shocked from whatever's left in the caps?
