FredA
- Dec 15, 2013
Never had this issue. But i always start my steamer after the DI. And the dac after the DI too.So it's channel inversion, not a phase inversion, am I right?
Three units:So it's channel inversion, not a phase inversion, am I right?
Yes absolutely. I find that the Afterdark master clock makes the gustard more refined, with a cleaner and richer sound in detail. They are subtle but noticeable improvementsDo you see improvements after adding external clock? While Gustard is reported to not benefit from external clock, I don't trust what is said on a Gustard section, it would be worth to hear first hand opinion.
Pairing DI-20/24 is not ideal, as Gustard do not support DSD autodetect, in result will not play DSD over I2S. However if you do not play DSD, DI-20HE is for now better option. Till a new firmware unlock S/PDIF port.
A feeling that music is more real.Yes absolutely. I find that the Afterdark master clock makes the gustard more refined, with a cleaner and richer sound in detail. They are subtle but noticeable improvements
I am on Linux. Could be os-related.Three units:
DI20 non HE 2019/2020
DI20HE from 2019/2020
DI20HE from late 2022
When these units turns on. The channels....Left and Right inverts/swap. It happens randomly, not every time
Nothing to do how it is powered on. However I do as recommended. Starting from Source then DI20HE then DAC then AMP. Opposite way when turning off
I have actually not tried source after DI20HE. That I will try. Thanks! -- even though my friend say he did that
I have not tried 24/7. I asked my friend and he says that it does not swap when it is on all day all year.
I am sure this is in the bootsequence of no matter which DI20/HE. The problem is fixed with leaving it on 24/7
I remember when reading implementation of Texas Instrument isolator chip which is present in DI-20, there was a note about power-on initialisation sequence with a warning that on some condition output level(s) could reversed, but do not remember details. You can pass this suggestion to Kingwa anyway, it could be a case.I am sure this is in the bootsequence of no matter which DI20/HE. The problem is fixed with leaving it on 24/7
But I wouldn't recommend following these instructions.According to the description on the official website, it can be applied to our products, but in reality, software updates are needed to determine if it is compatible with your system.
You can choose this firmware to update: cpld_1082 and firmware_2006be15r2
It is the Linux-compatible firmware of Amanero.
Best regards.
The differences are subtle with te gustard r26; but when i exclude the Afterdark ( queen 50 ohm square wave two outputs) it’s as if something is missing from the sound. It’not psycho acoustics.A feeling that music is more real.
With the he7 mkii, the sound has more staging depth. Like a flat plane of instruments in comparison with the internal. Still excellent technically, even smoother on the internal.
Also, the reverberations are almost not there on the internal in comparison. Bass has also better definition. Both are very enjoyable but the external makes the sound more real.
Exactly. Life is missingThe differences are subtle with te gustard r26; but when i exclude the Afterdark ( queen 50 ohm square wave two outputs) it’s as if something is missing from the sound. It’not psycho acoustics.
Presumably a minor upgrade. You'll have to ask audio-gd. Nobody tried this combination AFAIK.Hi there's just want to ask, recently I have bought R-28 2022, Ive tried the r28 with DI-20he which obviously sounds fantastic, how does the r28 sounds with the di-24he?
Im running speakers and headphones (Precision 3 power amp).
Alright thx for the reply,Presumably a minor upgrade. You'll have to ask audio-gd. Nobody tried this combination AFAIK.
Other than on the isolator (tricky part, as it has to pass DC over a barrier) it is difficult to get reversed polarity in a DC-coupled circuits.
Start playing a music before turning DDC on (or in the same time if stops with error). It will likely trigger swapping more frequently.I would really appreciate a DI24HE owner making this test to verify. I never leave 20Watts/DI20HE on all the time.
1. Turn off DI24HE everytime after use.
2. Turn on the next day when use
So far I have done two starts with the DI20HE first, then source, and it seems fine....if the third one swaps then it has a pattern. DI24HE should not have this problem, I edited the previous post, I got magna to test it, and they confirm no issues at all.Start playing a music before turning DDC on (or in the same time if stops with error). It will likely trigger swapping more frequently.
