The burn in is quite annoying. The fluctuations, losing bass and coming back day by day, volume is low today.
Good news is only 940 hours left to go.
You don't need to burn in the DI-20HE for 1000 hours before it sounds at it best. 200 hours is enough.The burn in is quite annoying. The fluctuations, losing bass and coming back day by day, volume is low today.
-110dB @1hz is excellent at the price point, if real. Looks well made.What can we think about this clock?
https://www.beatechnik.com/product-page/lhy-ock-1
It can be found cheaper on Ali...
I'd like to find a European source for that. Thanks for this link.What can we think about this clock?
Well I hope you're right.You don't need to burn in the DI-20HE for 1000 hours before it sounds at it best. 200 hours is enough.
WTH, I just ordered the Gustard C2 clock cable.
https://aliexpress.ru/item/1005004167277639.html?sku_id=12000028255397665Что мы можем думать об этих часах?
На али можно найти дешевле...
Indeed. If all is as stated, this is a huge bargain.https://aliexpress.ru/item/1005004167277639.html?sku_id=12000028255397665
Very interesting, I think it would be a good addition to the DI20HE, there is no alternative at this price.
The HE has a regenerative power supply, internal clock is oven controlled vs temperature on the SU-6 (OCXO is more accurate), galvanically isolated, more advanced USB interface.Hi. Which is a better DDC, the DI-20HE or the SU-6? Please can you explain why if you are able to share an opinion? I don’t believe the answer must be only because the DI-20HE has an external clock and the SU-6 does not.
I used to own an SU-6... the DI-20HE is a much better sounding device, in my opinion.Hi. Which is a better DDC, the DI-20HE or the SU-6? Please can you explain why if you are able to share an opinion? I don’t believe the answer must be only because the DI-20HE has an external clock and the SU-6 does not.
