sajunky
Well, WiFi is the best, but not the internal WiFi. You missed a whole point. You should try WiFi extender, disable internal WiFi.Tried many solutions. Not good. Wifi is best.
You need a dual psu, with two separate windings at least and separate rectifiers. One 5v source is for the usb side, another one is for the clean side. Maybe you'll get close to a HE. Not sure.Hi guys, so I take it that's it's possible to power the DI-20 from a 5V supply? Would I need dual 5v DC power or just one? I have a very good DC LPS with supercaps that outputs 5V.
If so, I assume that would put the DI-20 performance closer to the DI-20 HE - even moreso the HE version would become unnecessary right?
Nope..Im running a custom psu with 6x lt3045 on the zen stream. These wifi extender won't have the same power quality and will just ruin it. I've already powered switches with the hypsos and it's .Well, WiFi is the best, but not the internal WiFi. You missed a whole point. You should try WiFi extender, disable internal WiFi.
Nonsence, internal WiFi is a reason you need so many devices. And you didn't try the extender yet.Nope..Im running a custom psu with 6x lt3045 on the zen stream. These wifi extender won't have the same power quality and will just ruin it. I've already powered switches with the hypsos and it's .
Nonsense. There is no reclocking on Ethernet, but asynchronous data delivery, similar jitter-free method like with USB.As you can see, I understand the limits of reclocking. Typical wired Ethernet (and added sfp+ option) has too much reclocking that may be same same different different and powered with poor psu quality will bring more problems than solutions. Each device the data hops on from modem to router to switch to sfp or whatever gets worse. Each stage, there is reclocking.
The whole connectivity idea is to not break asynchronous datastream delivery. In this way reclockers are completely redundant and the only clock that maters is internal DAC clock. It is DI-20 thread, I answer that way. Get a better DDC and get rid of all this unnecessary stuff.But each device has a clock right? So there u go.
True, a good DDC which do not reclock when not neccessary helps, exactly what I wrote.It will still need a ddc. So after all that, a ddc will still help. Exactly...
The big transfo hums a bit here. Nothing major. Pretty common i would say with the di20he.Quick question for anybody that has a DI-20HE, maybe you could test this for me.
Want to know if this is normal, or if I need to send my 20HE back to Kingwa for a look over.
I have the US 120v version, and after about 2-3 minutes of being on, it has coil wine (assuming from the class A transformer setup).
It's not that loud, but in a dead quiet room, can be slightly audible from as far as 6ft away.
If anybody tests their own unit for me, just put your ear close to one of the vents top or bottom, should be easily audible.
Thanks!
That's terrible. No noise here.
