Originally Posted by noinimod /img/forum/go_quote.gif
Nice, keep us updated with your impressions
Hmm right now i'm wondering if i should just get the DF version. I find it hard to justify the extra USD150 just for a different filter chip (and different capacitors). The DSP1 upgrade is almost a good 30% more top-up from the DF. I've tried googling but there isn't much info on the DSP1
The DSP1 is more like a CPU (Pentium II) than just a filter chip...it has up to 4 PLL circuits, 16 global clocks, proper termination of the digital signal in single ended and differential modes, on board cache memory many times the size of standard filter chips and a few other features that slip my memory ATM. In addition to those features it's PLL circuits are 100% phase correct which is very very important, combined with the DIR9001 input receiver and BNC connections it's jitter rejection is outstanding. It's also a high bandwidth high speed processor (250 MHZ) rather than just a filter chip. It gives you options the DF1704 just can't match like OS rate choices (0X or NOS, 2X,4X and 8X), stop band filter slope rates (-50db,-90db,-130db) I2S data format from DIR9001, Three-stage linear-phase ( group delay distortion : Zero) FIR filter configuration, Passband: 0~0.4535Fs/Passband Ripple: within ±0.00001dB, etc etc...
Here is the link to the DSP1 page at A-gd
http://www.audio-gd.com/enweb/DACRE1.htm and the relevant page of the manufacturer of the chip (Altera Cyclone II)
Download FPGA
The usual application for this chip is HDTV processing (1080P) but it can also be used to process digital audio (obviously). It's a novel use of technology and well worth the additional cost IMO.
The technical aspects of the Altera page are little hard to wrap your head around if you don't have a foundation in the basics of digital transmission theory/practical application (something I'm constantly working on with a layman's POV/education) but with a little digging and research you can make some meaningful headway.
I hope that helped fill some of the gaps about this chip and it's first time use in this way.
Peete.
