Allanmarcus Well, if harshness is not an issue, then oppo ha-1 looks like good option. Build quality, exterior and features.
Personaly, i'm done with all that delta-sigma, especially sabre, and find myself happy in a NOS world
I went back and forth between purchasing the Oppo HA-1 and the 10.33. Oppo even let me demo a unit for 3 weeks. I felt it was quite the profound upgrade from my humble setup at the time. Ultimately, I had the opportunity ( <-- sorry for the Oppo Pun) to get the 10.33 for a smoking deal and couldn't resist. I figured I could always just turn it around on the FS/FT thread, if all else failed. Having the chance to listen to my friend's NFB-2 setup, I wasn't expecting all that much, honestly. When I couldn't stop listening, and really never had ear fatigue, it was pretty clear to me that I wouldn't need to upgrade to the HA-1.
Here's my impressions. The HA-1 pairs so well with my HE-4, that I nearly bit the bullet and bought the HA-1 on the spot. It also sounded great with the Grados, and good with pretty much everything else. The HD800s sounded great, but only for about 15 minute sessions before I had to take a break. The HA-1 did everything well, but only drove one pair GREAT. It's well built, solid, and gorgeous. The interface is good, but not perfect, but certainly more polished than more Hifi gear with digital interfaces.
If you're looking for an amp that will work with everything, great detail, tight bass, then the HA-1 might be for you. Yes, it's more polished than Audio-GD products. It can even be used as a pre-amp, which it did quite well. But what I noticed was the same as many mentioned before, the HA-1's dac just doesn't seem to be on the same level as the amp. I couldn't justify purchasing a $1200 unit and need to start looking for a dac to pair with it. I noticed, while testing current dacs that I had at the time, the HA-1 was a bit picky.
As for the NFB-10.33, I can tell you this, I haven't been tempted to purchase the Oppo since. I would suggest getting the TCXO upgrade, and the both SPDIF modules, even if you don't plan to use them. The DIR9001 is certainly the way to go from my experience. There's something very musical about the Wolfson chip, and it might not sound super exciting the first time you listen, but once you give your brain some time to burn in, everything else feels harsh or artificial!
I ended up purchasing the remote later, and never use it. My 10.33 just sits near my keyboard, so it's actually easier to use the knob. If I were to upgrade, there's a chance I would find the remote useful, but certainly not necessary.
PS, as to the comment above, I found I do not like the Sabre sound either. Maybe in 10 years, there will be a more balanced implementation of it, but until then...
