I haven't heard either the 11.32 or 15.32, I would guess that SQ is pretty good on any of these DAC/AMPs. The 11.32/15.32 seem to be much cheaper, although I'm not sure the 15.32 is actually available from Audio-GD anymore (don't see it on the products page). The 11.32 does have the Sabre DAC so I'm not sure if you'll experience anything different from it over the dual wolfson in the 10.33, but we just discussed this in the above posts that it's not likely going make much of a difference, although there seems to be a great deal of debate over audible differences in DACs in general.
I would suggest you consider the Amp capabilities, connections and general features (volume control, size of enclosure, etc) in comparing the products, and of course, the price.
I went for the bigger 10.33 because I wanted XLR outs for my monitors and a powerful amp so I have future upgradeability for headphones, should I get something that is harder to drive in the future.
I'll mention that the 4pin XLR balanced output on the 10.33 was a pleasant surprise for me. The balanced output sends a lot more power to the headphone and it results in very clean sound, I prefer it a lot over the single ended cable (I've also seen other people debate the differences between balanced and 1/4" on this forum, but as far as I can tell there is an improvement). I've only used the balanced output with my Alpha Dog but even switching between the 1/4" and the 4 pin XLR with just this headphone on the 10.33, I definitely believe I notice a difference.
If you're not using a balanced cable with your headphones and don't intend on having balanced cables in the future with your existing or any new headphones you'll probably be less interested in the 10.33 as much of it's design is catered to balanced output.
