siles1991
- Apr 12, 2013
Electricity is so completely not like water that beyond explaining the basic concept of what a current is to a schoolchild it really is totally unsuitable. It provides a nice visualisation for people without any training in electrodynamics but you can't look at anything water does and say that works for electricity.
In your analogy you mention that a "smaller pipe" has more "resistance" which isn't actually true for water. I assume what you're thinking about is back pressure. While it is true that this back pressure is exerted in such a situation the velocity of the water actually increases to compensate. And this is all actually for a pipe changing in size from large to small in an open circuit, not a small pipe in a closed circuit. The increase in back pressure is caused by the horizontal component of the pair of the force applied to the water in forcing it into a narrower gap (by Newton's 1st law). It is not something inherent to the smaller pipe which causes this, it is the act of moving the water outside of the small pipe diameter into the small pipe. The only reason in this situation the flow volume drops is because the water coming into the pump is at a certain pressure and you're increasing the pressure of that which is coming out of it, giving a pressure differential which tries to make the water flow the wrong way. If you have a small pipe in a closed circuit you can easily get the same flow volume by increasing the pressure of the water you put into it. The pressure is equal either side of the pump and apart from the risk of explosion everything acts pretty much the same. Assuming you don't pressurise it enough to cause it to phase change or considerably alter its viscosity. So in the water analogy the size of the pipe doesn't matter apart from explosion risk unless you increase the pressure to a degree at which it creates ice or something approaching ice.
Most importantly, not a single thing I just said occurs with electricity. So the entire analogy is faulty and you cannot derive the behaviour of electricity from that of water, even if you had understood the behaviour of water correctly. Water also doesn't have capacitance or inductance to worry about. And electricity doesn't have viscosity, pressure etc.
Yes it is true that thicker wires have a lower resistance, but the resistance changes are only a small part of what happens. When you increase the wire size you also reduce the inductance and increase the capacitance. This has a whole host of potential effects.
The effect on the resistance as has already been discussed is really very tiny. I myself made the mistake earlier in this thread of thinking it may be significant when I messed up some mental arithmetic, but sadly it is far too small to explain any possible differences. The relationship between the inductance and capacitance is where things might be explained if indeed they do actually exist at all.
Your final statement bemuses me greatly. To seek to give a physical explanation and then end with denying the premise of physical measurement is something I struggle to comprehend. Everything you think you know about your explanation is based on scientific measurements and/or fundamental mathematics. The human ear is a horrifically inaccurate measuring device. If you want to know the accuracy of human measuring place one hand in ice and the other in hot water. Now place them both in tepid water. You're brain will tell you it is both cold and hot at the same time. A digital thermometer may have an error of +-0.1% giving equal degrees of "fluctuation" but your brain can't even tell you if it's warm or not. Compare the thermometer graph to your perception graph and you'll see clear data next to a dartboard. We can measure the signals in wires down to less than +-0.01%, the human ear can't. Yes there may be something happening we haven't decided to measure yet (that's a huge maybe at best), but you can't possibly say that the human ear can compare to a modern graph. You can argue we might have the wrong graph, but that's about it.
Firstly "I agree electricity is not like water but I had no idea how else to explain my theory haha" secondly its a theory that I claimed that should not be taken seriously. Third im not an electric engineer. Fourth yes I damn well know electric is not the same I used it due to the lack of the right words I already stated it in my post if you bothered to read that part. Fifth frequency graphs are fine but this is audio you listen with your ears. You dont listen using graphs on a computer audio is subjective. So yes ears are the best measuring tools you can have. In the end what you hear is important not graphs. They can be guidelines but not a definitive answer. Sixth dont need to be a keyboard warrior about something I already said was a random theory, and should not be taken so seriously. Need me to repeat myself further?
