SteeleBlayde
- May 6, 2003
I dont think the Cardas Golden References are made out of solid 24K gold...... LMAO.
Originally posted by pbirkett Its a myth that silver cables are brighter, although I have found that silver coated copper cables are a lot brighter, but never pure silver. They are more detailed and smoother however. |
Originally posted by SteeleBlayde I was always under the impression that silver was the best material for wire plating... Something about being the best material for reducing skin effect. |
Originally posted by kuma I think material used for conductor alone can't determine how they sound at the end. It seems many other variables influence the outcome. |
Originally posted by fewtch Hate to say it, but the idea that a cable could emphasize certain frequencies is a little more far out than the idea a cable could roll off frequencies (which maybe could happen in extreme cases of capacitance issues with the cable). These are not transducers, they're electrical conductors -- they do nothing but conduct electricity. Look at it this way -- imagine you've got input and output jacks on a headphone amp. Between the input and output jacks are nothing but a bunch of thin traces on a circuit board, with some electrical components in there that have tiny, thin leads on them. I can't conceive how connecting a silver cable to the input and output jacks would do anything with those tiny, thin circuit traces and aluminum component leads in between the two. Not to mention when the signal passes through an op-amp, which contains some almost microscopic transistors, etc. You want to put a thick cable on the input and output, what's that gonna do? |
Originally posted by fewtch You want to put a thick cable on the input and output, what's that gonna do? |
