Maelob
- Aug 15, 2012
I'm interested in these as well. I hope the bass is good.
+1, I hope they sound a little more exciting than the PM-3s
@XERO1 Looks like you are based in SoCal. Want to come by next week and check out the SQ on Sine ?
XERO1 - Did you ever take up the offer and audition the Sine?
XERO1,
Thanks a ton for the writeup and for taking the time to share your experience checking out the Sine. A couple of questions:
1. You mention $499 Sine will include both the Cipher cable and a standard cable. If that's true it would be great, as I think the early press I read made it sound like the Cipher cable would be a $100 add-on to the "standard" $499 Sine. Can you confirm that they will include the Cipher cable for the $499 price?
2. If you've listened to the Oppo PM-3s, do you have a favorite between that and the Sine? I realize one is over ear and one is on ear, but just curious if the Sine is $100 better than the PM-3.
Thanks again!
Looks like the pricing has now changed according to the Audeze site, with $499 being the price with the Cipher cable and the standard cable being $449. Cheers
No plan for a open back version?.
Obviously, if you don't plan on using an iDevice for music playback, I would say no.
But if you are going to be using an iDevice, than I would say it's definitely worth it just for the in-line controls alone. Plus, the EQ feature is pretty cool. One thing that Sankar explained to me was that if you use a basic software-based EQ app on an iDevice, there are certain audio streams that may not be compatible with the software-based EQ and it will be bypassed without telling you, but because the Audeze EQ is firmware-based and permanently stored in the Cipher cable, all audio streams will have the selected EQ curve applied to them 100% of the time.
And Audeze plans on adding even more capabilities to the Cipher cable down the road, so I'd say it's totally worth the extra $50 bucks.
The SINE's are primarily intended to be used as a portable headphone that you can happily take out-and-about and use while around other people, so having an open-back version wouldn't make much sense due to sound leakage and isolation issues.
Try this web page:
https://www.audeze.com/contact-us
Also, if you are under 30, you may not realize this, but your smartphone has a realtime, voice enabled, universal communication app built right it! Open the "phone" app and look for the something call a "keypad". Enter this secret code for Audeze and press the green button. (714) 581-8010.
Then hold the top part of the smartphone to your ear and the bottom part of the smartphone to your mouth. After the connection is made with Audeze, you can talk and the person on the other end can hear you! WAY faster than e-mail, twitter, texting, instagram, pinterest, Facebook, Google+, or even LinkedIn!
