jagwap
Is there anywhere that you can buy a cypher cable?
I don't want mine. My passive cable is getting unreliable. I would swap it for a good passive cable.
Can yoy give a link where i can buy these? From Europe..I've been to-ing and fro-ing on a couple of earpads and the ones that are staying (for the moment anyway) are these MSR7 clones.
To my ears at least, they're about as close to stock sound as I've been able to get - they've been able to capture the immediacy and the bass texture that I love about the Sines, and which were too significantly compromised by the Brainwavz ones (I have flat pleather and hybrid ones, as well as angled velour ones) for them to be viable, comfy as they were. The Brainwavzs opened up the soundstage (which was nice) but were ultimately too distant and unfocused.
Plus the MSR7s fit quite securely without the need for adapters and don't add as much bulk to the Sines, as you can see:
P.S.: Big thank you to @ASRSPR for the adapter download - I didn't need it with the MSR7 after all, but it helps loads with keeping the bigger pads secure.
I just found Sines for me, they are coming for me next week. Best pads which goes straight on to the Sine without adapters?
And i prefer Pads that don't change the soundsignature at all.
I recommend finding pads made for the Skull Candy Aviators
Bought those. Also got a 3 dollar discount when shopping for 4 dollar...
Let's hope they are better then the Audeze ones and the Sonys I have tested.
Does anyone know if these connectors fit Sine:
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
How about these? I have to buy them inside of europe.The same pads in following post:
Not to your ears only...
The "MSR7 clones", which are the aftermarket Audio Technica pads, look and behave superior to the real Audio Technica pads.
Yes, they can fit loosely on sine , but I prefer the fit of member ninja adapters on them.
Coupled with the bose lettered felt covers, they are the best setup I have tried..
And I tried them all, including the versper, the authentic audio Technica, and also the cheaper adapters .
Most pad solutions will give you either distant or "U" shaped sound, so beware other pads...
Here is a pic of the "MSR7 clone" pads:
Here is a pic of the bose QC25 lettered felt cover wich I use in combo with the pads :
They come in different
Colors and definitely worth it to distribute the trebles evenly .
So at least you can save the felt covers when you toss away the cheap small bose pads.
I actually place them last, inside the pad, not before as this pic might suggest. .
Sines are here. The sound is fantastic!
2nd hand from Sweden, mint condition.Purely out of curiosity, where did you buy them?
