That $379 price only shows up with the link you provided. If you search for the Sine manually, you'll only find the $449 and $499 versions of the Sine, minus the bundles they offer. I wonder if it will let you go all the way through the checkout process without correcting the price. Crazy
Yes, it let me get all the way through checkout to "place order" button with free shipping. I logged in, filled in my cc info, and got to very last screen "place order" with the $379 price. There was sales tax added because i live in NY.
I recently got the Sine. I also have the brainwavz angled pleather earpads, and I am thinking of putting them on the Sine to see how they work in terms of comfort and sound (following the advice from High-End-Addict). Is there any special instructions for removing the original earpads and putting on the new ones. Don't want to mess with $500 headphones without being sure.
I almost wish I had waited to purchase mine. That deal was really good. Oh well. I think I'm getting a galaxy this weekend so the cipher will be a none issue for me now.
I´v replaced my sine pads with brainwave angled. Taking off the original pads is VERY easy. Just pull them off. Put your thumb inside and pull gently out. Very little force needed.
But putting the branwavz on is a bit harder. Just start from one side and don´t be afraid to really stretch the inner lining. I used 20 minutes on the first pad, and 1 minute on the next one - when I found out that they are really flexible and could stand a bit of powerful stretching.
Not very special instructions. But it´s not that hard either.
Can someone measure inside diameter of stock pads of the sine? my ears dont accept on ear and i dont want to spend 500dollars on headphones and changing pads immediatelly my ears are really small so there is a hope
Just received 3D printed kit from Inertianinja with Msr7 pads. Only listen a short while. I wanted to test them at once and forgot to listen closely to the original pads before I shifted, and my audio memory are short.
With msr7 pads on 3D kit Sine became almost like another headphone comfort wise. And if I remember correctly the sound also is a bit different. I'm not going to try to explain much about the difference. I need more time and alter the pads which I'm not so glad to do.
But correct me you that have tested them if I'm wrong. I feel like details are more with msr7 pads and they're brighter sounding. Don't remember original pads gave this kind of details. But maby I remember wrong.
Maby the brightness is because original pads put pressure on my ear canal which in my case is rather high and narrow. When I opened my mouth it became brighter. And msr7 pads don't put pressure on that area.
When I ordered them I didn't now about the over ear pads that are made to fit Sine. Would be interesting to hear from you later that have tested them and msr7 pads. But I don't regret buying these. Inertianinja haw been great to buy from.
Thank you, Eide!
Yesterday night I took the risk and replaced the pads with the Brainwavz ones. I didn't have the chance to test them for long (will do that this weekend), but they seem to be somewhat loose fitting to me. What I am looking for is increased isolation and some relief from the sound change at the slightest head movement.
