Yes, we will.I would also feel better if @Audeze would confirm that they will honor their return window if your support issue was logged within the specified period.
Stay updated on Audeze at their sponsor profile on Head-Fi.
I don't know why nobody is talking about battery life and charging time. The maximum gameplay I could get out of these headphones was 12 hours, and also charging with 5V/1A takes almost 5 and a half hours. Charging it 5 hours and getting out 12 hours of gameplay until it completely shuts off does not seem practical. I thought I could get something close to 15 hours with these, and also, I was expecting them to charge fully in 3 hours with 5V/1A charger, as advertised.
I have an Amplifi HD router and there is a setting that might help. It's in Wireless Settings > Advanced > 2.4Ghz Bandwidth. Set it to the minimum 20 Mhz which I believe should reduce the bandwidth it uses that might interfere with Penrose.
Totally agree with this, I hope this can be addressed in a future firmware updateAnyone else feel that holding the button to re-power it on for 3 seconds is too long? I want a quick depression and for it to swing into life. 3 seconds feels like a lifetime.
I would not do that without asking Audeze support. I have heard that fast charging could shorten battery life in the long run. I am also really frustrated that these do not charge fully in 3 hours with 5V/1A charger as advertised.What if I use a fast wired charger that I got with my galaxy s20 plus? It's up to 3amps. Will this cause an issue and hurt the headset or just charge faster. Or about the same?
Just so you guys are aware I think its been confirmed by others (and by myself as well) that the crackling/popping starts when the 2.4 ghz wireless starts going out of range. Mine is fine until I walk into my kitchen and it starts cracking/popping right before it loses connection.
I sit just a few feet away from my PS5 and I still get frequent crackling/popping.
Then you probably have interference. How far can you go before it loses connection and disconnects?
Set it to bitstream? In sound settings on series x correct?. Under which setting did you set it to bitstream? Because on series X only headset audio matters for a headset? The other is for speaker audio and thats for a receiver is that why?Mines been working weird on Series X. I have it set to bitstream, dolby and the headset to atmos. Whenever I turn off my headset it switches my av to stereo uncompressed.
Hdmi to bitstream. It actually worked today. Seems like it only changes if Im in the settings menu. I turned off the headset in game then checked the audio setting and they were right.Set it to bitstream? In sound settings on series x correct?. Under which setting did you set it to bitstream?
On the speaker settings right? thats for Av recevers you know? Anytime i select it i get a warning Its only Headset audio which matters mate. Unless you have hdmi headset selected?.Set it to bitstream? In sound settings on series x correct?. Under which setting did you set it to bitstream? Because on series X only headset audio matters for a headset? The other is for speaker audio and thats for a receiver is that why?
I have a soundbar I use it withOn the speaker settings right? thats for Av recevers you know? Anytime i select it i get a warning Its only Headset audio which matters mate. Unless you have hdmi headset selected?.
Will there be a way to change Bluetooth and 2,4ghz volume separately on an iOS device?
As it is, with locked global volume, you can’t use both really at the same time as the Bluetooth is too loud to mention game sounds...
Would be nice if we could at least set it via the Audeze hq.
there are 2 functions on the mic wheel. Why not on the volume too?
