Audeze Mobius review / impressions
May 21, 2020 at 10:47 AM Post #4,801 of 5,780
This EQ is on top of Neutral settings on Mobius ?
UPDATED VERSION HERE
RTings measurements I believe were for the Default preset, at least their Test Settings state such, and likely measured pre v5 firmware. I think though v5 Flat is more similar to pre-v5 Default? If so then its for Flat, if not then Default. I think 3D mode was off as well for the measurements, though this EQ works either way
EDIT:
For expanded use of a Harman target curve EQ for the Mobius, I'm adding generated Parametric EQ and Fixed Band (standard 10 levers) versions, as well as the AutoEQ command line I used to generate it. Should be accurate, only way to get it more accurate is for oratory1990 to measure it in Hi Res mode on Flat v5. If your just after the EQ for EqualizerAPO, use the Graphical EQ or Convolution options. Convolution & Parametric is usable in Roon, Parametric in USB Audio Player (Android) and more, while Fixed Band is your more generic equalizer.
Only Parametric/Fixed Band need a preamp, Graphical and Convolution have it baked in.
Neutral EQ, equivalent to the Harman curve
Parametric EQ (10 band):
Channel: ALL
Stage: post-mix
Preamp: -7.5 dB
Filter 1: ON PK Fc 27 Hz Gain 1.8 dB Q 1.39
Filter 2: ON PK Fc 186 Hz Gain -3.1 dB Q 1.30
Filter 3: ON PK Fc 4638 Hz Gain 6.6 dB Q 2.68
Filter 4: ON PK Fc 23707 Hz Gain -1.7 dB Q 0.56
Filter 5: ON PK Fc 23937 Hz Gain 2.5 dB Q 1.79
Filter 6: ON PK Fc 402 Hz Gain 2.1 dB Q 2.02
Filter 7: ON PK Fc 539 Hz Gain -1.4 dB Q 0.90
Filter 8: ON PK Fc 3347 Hz Gain -3.9 dB Q 2.46
Filter 9: ON PK Fc 3974 Hz Gain 4.8 dB Q 6.35
Filter 10: ON PK Fc 6643 Hz Gain 3.3 dB Q 5.98
Parametric EQ (24 band):
Channel: ALL
Stage: post-mix
Preamp: -7.5 dB
Filter 1: ON PK Fc 26 Hz Gain 2.0 dB Q 1.51
Filter 2: ON PK Fc 84 Hz Gain 0.8 dB Q 1.71
Filter 3: ON PK Fc 196 Hz Gain -3.2 dB Q 0.79
Filter 4: ON PK Fc 381 Hz Gain 2.5 dB Q 1.51
Filter 5: ON PK Fc 591 Hz Gain -1.3 dB Q 0.86
Filter 6: ON PK Fc 2914 Hz Gain -1.9 dB Q 3.18
Filter 7: ON PK Fc 3376 Hz Gain -4.4 dB Q 3.70
Filter 8: ON PK Fc 4170 Hz Gain 8.4 dB Q 2.35
Filter 9: ON PK Fc 6577 Hz Gain 2.9 dB Q 4.20
Filter 10: ON PK Fc 21891 Hz Gain -0.7 dB Q 1.29
Filter 11: ON PK Fc 47 Hz Gain -0.4 dB Q 0.62
Filter 12: ON PK Fc 64 Hz Gain 0.4 dB Q 2.62
Filter 13: ON PK Fc 561 Hz Gain -0.3 dB Q 2.55
Filter 14: ON PK Fc 671 Hz Gain 0.2 dB Q 0.97
Filter 15: ON PK Fc 1207 Hz Gain -1.0 dB Q 4.47
Filter 16: ON PK Fc 1452 Hz Gain 0.6 dB Q 2.20
Filter 17: ON PK Fc 1781 Hz Gain -0.4 dB Q 2.70
Filter 18: ON PK Fc 2159 Hz Gain 1.1 dB Q 4.03
Filter 19: ON PK Fc 2604 Hz Gain -0.7 dB Q 5.06
Filter 20: ON PK Fc 5190 Hz Gain 0.1 dB Q 1.09
Filter 21: ON PK Fc 7209 Hz Gain 0.8 dB Q 3.93
Filter 22: ON PK Fc 7260 Hz Gain 0.3 dB Q 3.35
Filter 23: ON PK Fc 7263 Hz Gain -0.1 dB Q 0.82
Filter 24: ON PK Fc 8116 Hz Gain -1.3 dB Q 3.27
Fixed Band (10 lever):
Channel: ALL
Stage: post-mix
Preamp: -4.5 dB
Filter 1: ON PK Fc 31 Hz Gain 1.5 dB Q 1.41
Filter 2: ON PK Fc 62 Hz Gain 0.3 dB Q 1.41
Filter 3: ON PK Fc 125 Hz Gain -1.7 dB Q 1.41
Filter 4: ON PK Fc 250 Hz Gain -1.9 dB Q 1.41
Filter 5: ON PK Fc 500 Hz Gain 0.4 dB Q 1.41
Filter 6: ON PK Fc 1000 Hz Gain -0.7 dB Q 1.41
Filter 7: ON PK Fc 2000 Hz Gain -1.3 dB Q 1.41
Filter 8: ON PK Fc 4000 Hz Gain 4.0 dB Q 1.41
Filter 9: ON PK Fc 8000 Hz Gain 1.1 dB Q 1.41
Filter 10: ON PK Fc 16000 Hz Gain -0.4 dB Q 1.41
Graphical EQ:
Channel: ALL
Stage: post-mix
GraphicEQ: 20 -6.0; 21 -5.9; 22 -5.8; 23 -5.7; 24 -5.7; 26 -5.5; 27 -5.5; 29 -5.5; 30 -5.6; 32 -5.8; 34 -6.1; 36 -6.4; 38 -6.7; 40 -7.0; 43 -7.2; 45 -7.2; 48 -7.2; 50 -7.2; 53 -7.1; 56 -7.0; 59 -7.0; 63 -7.0; 66 -7.0; 70 -7.0; 74 -7.1; 78 -7.2; 83 -7.4; 87 -7.5; 92 -7.6; 97 -7.8; 103 -8.0; 109 -8.3; 115 -8.6; 121 -8.8; 128 -9.1; 136 -9.4; 143 -9.5; 151 -9.7; 160 -9.8; 169 -9.9; 178 -10.0; 188 -10.0; 199 -10.1; 210 -10.0; 222 -9.9; 235 -9.7; 248 -9.4; 262 -9.1; 277 -8.8; 292 -8.4; 309 -8.0; 326 -7.5; 345 -7.2; 364 -7.1; 385 -7.0; 406 -6.9; 429 -6.9; 453 -7.1; 479 -7.4; 506 -7.8; 534 -8.1; 565 -8.3; 596 -8.3; 630 -8.2; 665 -8.1; 703 -8.0; 743 -8.1; 784 -8.1; 829 -8.1; 875 -8.0; 924 -7.9; 977 -7.8; 1032 -7.8; 1090 -8.1; 1151 -8.3; 1216 -8.2; 1284 -7.9; 1357 -7.5; 1433 -7.2; 1514 -7.1; 1599 -7.2; 1689 -7.3; 1784 -7.3; 1885 -7.0; 1991 -6.7; 2103 -6.5; 2221 -6.6; 2347 -7.1; 2479 -7.8; 2618 -8.5; 2766 -8.9; 2921 -9.1; 3086 -9.1; 3260 -8.9; 3443 -8.0; 3637 -5.8; 3842 -2.6; 4058 -0.5; 4287 -0.5; 4528 -1.2; 4783 -1.7; 5052 -2.5; 5337 -3.7; 5637 -4.4; 5955 -4.0; 6290 -3.3; 6644 -3.3; 7018 -3.8; 7414 -5.0; 7831 -6.7; 8272 -7.4; 8738 -7.2; 9230 -7.2; 9749 -7.2; 10298 -7.2; 10878 -7.2; 11490 -7.2; 12137 -7.2; 12821 -7.2; 13543 -7.2; 14305 -7.2; 15110 -7.2; 15961 -7.2; 16860 -7.2; 17809 -7.2; 18812 -7.2; 19871 -7.2
Convolution EQ:
(Add both .wav files specifically in EqualizerAPO, will use 48k in 7.1/Stereo, and 96k in High Res). Paste in /config folder.
See post attachments.
Warm EQ
Channel: ALL
Stage: post-mix
Preamp: -6.5 dB
Filter 1: ON PK Fc 25 Hz Gain 1.8 dB Q 1.51
Filter 2: ON PK Fc 183 Hz Gain -2.7 dB Q 1.39
Filter 3: ON PK Fc 3271 Hz Gain -3.9 dB Q 2.93
Filter 4: ON PK Fc 4183 Hz Gain 7.1 dB Q 2.86
Filter 5: ON PK Fc 6742 Hz Gain 2.5 dB Q 4.27
Filter 6: ON PK Fc 396 Hz Gain 1.6 dB Q 2.54
Filter 7: ON PK Fc 642 Hz Gain -0.9 dB Q 0.62
Filter 8: ON PK Fc 2095 Hz Gain 1.1 dB Q 4.45
Filter 9: ON PK Fc 7370 Hz Gain 0.9 dB Q 4.04
Filter 10: ON PK Fc 8141 Hz Gain -1.1 dB Q 3.16
Parametric EQ (23 band):
Channel: ALL
Stage: post-mix
Preamp: -6.5 dB
Filter 1: ON PK Fc 26 Hz Gain 1.9 dB Q 1.53
Filter 2: ON PK Fc 87 Hz Gain 1.7 dB Q 1.09
Filter 3: ON PK Fc 233 Hz Gain -3.6 dB Q 0.40
Filter 4: ON PK Fc 374 Hz Gain 3.5 dB Q 1.38
Filter 5: ON PK Fc 2116 Hz Gain 1.1 dB Q 4.22
Filter 6: ON PK Fc 3247 Hz Gain -5.8 dB Q 2.36
Filter 7: ON PK Fc 4124 Hz Gain 7.8 dB Q 1.78
Filter 8: ON PK Fc 22747 Hz Gain -1.5 dB Q 1.18
Filter 9: ON PK Fc 22893 Hz Gain -0.4 dB Q 1.46
Filter 10: ON PK Fc 23476 Hz Gain 1.7 dB Q 1.53
Filter 11: ON PK Fc 14 Hz Gain -0.2 dB Q 0.28
Filter 12: ON PK Fc 569 Hz Gain -0.2 dB Q 2.86
Filter 13: ON PK Fc 1018 Hz Gain 0.5 dB Q 2.51
Filter 14: ON PK Fc 1176 Hz Gain -0.5 dB Q 3.09
Filter 15: ON PK Fc 1186 Hz Gain -0.5 dB Q 3.78
Filter 16: ON PK Fc 1323 Hz Gain 0.4 dB Q 2.00
Filter 17: ON PK Fc 3004 Hz Gain 0.7 dB Q 3.93
Filter 18: ON PK Fc 3702 Hz Gain -0.7 dB Q 1.70
Filter 19: ON PK Fc 4101 Hz Gain 1.4 dB Q 7.52
Filter 20: ON PK Fc 4802 Hz Gain 0.9 dB Q 3.72
Filter 21: ON PK Fc 5613 Hz Gain -1.7 dB Q 1.70
Filter 22: ON PK Fc 6844 Hz Gain 3.8 dB Q 3.76
Filter 23: ON PK Fc 8037 Hz Gain -1.0 dB Q 2.21
Channel: ALL
Stage: post-mix
Preamp: -4.5 dB
Filter 1: ON PK Fc 31 Hz Gain 1.6 dB Q 1.41
Filter 2: ON PK Fc 62 Hz Gain 0.2 dB Q 1.41
Filter 3: ON PK Fc 125 Hz Gain -1.5 dB Q 1.41
Filter 4: ON PK Fc 250 Hz Gain -1.7 dB Q 1.41
Filter 7: ON PK Fc 2000 Hz Gain -0.9 dB Q 1.41
Filter 8: ON PK Fc 4000 Hz Gain 3.2 dB Q 1.41
Filter 9: ON PK Fc 8000 Hz Gain 0.9 dB Q 1.41
Filter 10: ON PK Fc 16000 Hz Gain -0.3 dB Q 1.41
Graphical EQ:
Channel: ALL
Stage: post-mix
GraphicEQ: 20 -5.0; 21 -4.9; 22 -4.8; 23 -4.8; 24 -4.7; 26 -4.6; 27 -4.6; 29 -4.6; 30 -4.6; 32 -4.8; 34 -5.1; 36 -5.5; 38 -5.8; 40 -6.0; 43 -6.3; 45 -6.3; 48 -6.3; 50 -6.2; 53 -6.1; 56 -6.1; 59 -6.1; 63 -6.0; 66 -6.0; 70 -6.1; 74 -6.1; 78 -6.2; 83 -6.4; 87 -6.5; 92 -6.6; 97 -6.7; 103 -6.9; 109 -7.1; 115 -7.3; 121 -7.6; 128 -7.8; 136 -8.1; 143 -8.2; 151 -8.4; 160 -8.5; 169 -8.6; 178 -8.7; 188 -8.7; 199 -8.7; 210 -8.7; 222 -8.6; 235 -8.4; 248 -8.2; 262 -7.9; 277 -7.6; 292 -7.2; 309 -6.8; 326 -6.4; 345 -6.1; 364 -6.0; 385 -5.9; 406 -5.8; 429 -5.8; 453 -6.0; 479 -6.3; 506 -6.7; 534 -7.0; 565 -7.2; 596 -7.2; 630 -7.1; 665 -7.0; 703 -6.9; 743 -7.0; 784 -7.1; 829 -7.0; 875 -6.9; 924 -6.8; 977 -6.7; 1032 -6.8; 1090 -7.0; 1151 -7.2; 1216 -7.1; 1284 -6.9; 1357 -6.5; 1433 -6.3; 1514 -6.3; 1599 -6.4; 1689 -6.4; 1784 -6.3; 1885 -6.0; 1991 -5.6; 2103 -5.4; 2221 -5.5; 2347 -6.0; 2479 -6.6; 2618 -7.3; 2766 -7.6; 2921 -7.7; 3086 -7.8; 3260 -7.7; 3443 -7.0; 3637 -5.0; 3842 -2.2; 4058 -0.5; 4287 -0.7; 4528 -1.4; 4783 -1.9; 5052 -2.8; 5337 -4.1; 5637 -4.8; 5955 -4.4; 6290 -3.5; 6644 -3.2; 7018 -3.3; 7414 -4.2; 7831 -5.7; 8272 -6.4; 8738 -6.3; 9230 -6.3; 9749 -6.3; 10298 -6.3; 10878 -6.3; 11490 -6.3; 12137 -6.3; 12821 -6.3; 13543 -6.3; 14305 -6.3; 15110 -6.3; 15961 -6.3; 16860 -6.3; 17809 -6.3; 18812 -6.3; 19871 -6.3
Convolution EQ:
Warmer EQ, closest to standard Mobius.
Channel: ALL
Stage: post-mix
Preamp: -5.0 dB
Filter 1: ON PK Fc 26 Hz Gain 1.8 dB Q 1.45
Filter 2: ON PK Fc 183 Hz Gain -2.3 dB Q 1.54
Filter 3: ON PK Fc 3302 Hz Gain -3.7 dB Q 3.13
Filter 4: ON PK Fc 4112 Hz Gain 5.8 dB Q 2.45
Filter 5: ON PK Fc 22762 Hz Gain 0.5 dB Q 2.24
Filter 6: ON PK Fc 398 Hz Gain 1.6 dB Q 2.56
Filter 7: ON PK Fc 608 Hz Gain -0.8 dB Q 0.60
Filter 8: ON PK Fc 2116 Hz Gain 1.2 dB Q 5.16
Filter 9: ON PK Fc 6591 Hz Gain -1.6 dB Q 1.81
Filter 10: ON PK Fc 7006 Hz Gain 3.8 dB Q 4.52
Parametric EQ (26 band):
Channel: ALL
Stage: post-mix
Preamp: -5.0 dB
Filter 1: ON PK Fc 26 Hz Gain 1.8 dB Q 1.66
Filter 2: ON PK Fc 83 Hz Gain 0.6 dB Q 1.72
Filter 3: ON PK Fc 188 Hz Gain -2.0 dB Q 0.93
Filter 4: ON PK Fc 384 Hz Gain 2.1 dB Q 1.89
Filter 5: ON PK Fc 507 Hz Gain -0.9 dB Q 0.46
Filter 6: ON PK Fc 2119 Hz Gain 1.2 dB Q 3.58
Filter 7: ON PK Fc 3276 Hz Gain -3.7 dB Q 2.59
Filter 8: ON PK Fc 4123 Hz Gain 6.0 dB Q 2.43
Filter 9: ON PK Fc 23160 Hz Gain 1.2 dB Q 1.85
Filter 10: ON PK Fc 23796 Hz Gain -1.0 dB Q 0.51
Filter 11: ON PK Fc 37 Hz Gain 0.4 dB Q 1.69
Filter 12: ON PK Fc 43 Hz Gain -0.5 dB Q 2.19
Filter 13: ON PK Fc 53 Hz Gain 0.1 dB Q 2.02
Filter 14: ON PK Fc 420 Hz Gain -0.2 dB Q 2.25
Filter 15: ON PK Fc 458 Hz Gain 0.3 dB Q 4.28
Filter 16: ON PK Fc 538 Hz Gain 0.2 dB Q 1.24
Filter 17: ON PK Fc 559 Hz Gain -0.6 dB Q 4.05
Filter 18: ON PK Fc 1018 Hz Gain 0.3 dB Q 4.05
Filter 19: ON PK Fc 1165 Hz Gain -0.7 dB Q 5.02
Filter 20: ON PK Fc 1344 Hz Gain 0.4 dB Q 2.01
Filter 21: ON PK Fc 1612 Hz Gain -0.2 dB Q 1.60
Filter 22: ON PK Fc 5004 Hz Gain 0.6 dB Q 3.52
Filter 23: ON PK Fc 5645 Hz Gain -0.7 dB Q 2.61
Filter 24: ON PK Fc 5660 Hz Gain -1.3 dB Q 5.46
Filter 25: ON PK Fc 7001 Hz Gain 3.2 dB Q 3.65
Filter 26: ON PK Fc 7890 Hz Gain -1.0 dB Q 2.00
Channel: ALL
Stage: post-mix
Preamp: -3.5 dB
Graphical EQ:
Channel: ALL
Stage: post-mix
Convolution EQ:
Optional brilliance/sparkle/air reduction, add onto above
Filter: ON PK Fc 10000 Hz Gain 0.9 dB Q 2
Filter: ON HSC 15 dB Fc 10500 Hz Gain -2 dB
Optional bass boost, add onto above
Filter: ON LSC 10 dB Fc 300 Hz Gain 1 dB
Optional diffuse-field addon, add this in EAPO to give the Mobius more of a diffuse-field response in the high treble, doesn't effect anything else. Could theoretically help spatial awareness and 3D mode. Definitely brighter with this, but also more 'wide' like theres a center channel, its hard to quantify. Worth testing AB.
GraphicEQ: 4700 0; 5100 1; 5850 1.4; 6650 0; 7782 -0.16; 7896 -0.48; 8010 -0.72; 8127 -0.96; 8245 -1.2; 8365 -1.44; 8487 -1.52; 8610 -1.6; 8736 -1.52; 8863 -1.36; 8992 -1.12; 9122 -0.88; 9255 -0.61; 9390 -0.32; 9526 -0.16; 9665 0; 9805 0.1; 9948 0.2; 10093 0.2; 10240 0.2; 10388 0; 10540 -0.1; 10693 -0.1; 10848 -0.1; 11066 0.1; 11166 0.5; 11329 1.1; 11494 1.6; 11661 2; 11830 2.3; 12000 2.5; 12177 2.5; 12354 2.6; 12534 2.6; 12716 2.7; 13089 2.7; 13279 2.6; 13472 2.4; 13668 2.1; 13867 1.7; 14069 1.4; 14273 1.1; 14481 0.9; 14692 0.7; 14905 0.4; 15122 0.3; 15342 0.1; 15565 0.2; 15792 0.4; 16021 0.7; 16254 1; 16491 1.2; 16731 1.3; 16974 1.4; 17726 1.3; 17984 1.3; 18245 1.4; 18510 1.3; 18780 1; 19053 0.4; 19200 0; 19839 -16
Result:
On:
Off:
Note, this is only 1/3rd of a full diffuse field correction. Can apply it multiple times or 3x each value to get the full effect. Remove the first 3 entries (4700-5850) to keep only the high-treble diffuse response for a more transparent version.
Optional LFE/Sub high pass filter for DTS-HD/Dolby TrueHD, most home theater amplifiers do this. Sometimes mixing rooms have their subwoofers high-passed and dont notice high-frequency noise/garbage they leave in the LFE channel. The Dark Knight is a good example of this. This removes it all, leaving only bass in the LFE and only on 7.1 tracks. Add onto above, make sure its the last addon
Channel: SUB
Filter: ON LPQ Fc 140 Hz Q 1.7
To generate these if anyone wants to, AutoEQ cmd settings
--input_dir="measurements/rtings/data/onear/Audeze Mobius" --output_dir="my_results/rtings/avg" --compensation="measurements/rtings/resources/rtings_harman_over-ear_2018_wo_bass.csv" --equalize --max_gain=30 --bass_boost=5 --parametric_eq --ten_band_eq --fs=48000,96000 --bit_depth=24 --f_res=5 --sound_signature="ss.csv" --treble_gain_k=0 --show_plot --convolution_eq --treble_f_lower=8000 --treble_f_upper=9000
AutoEQ sound signature 'ss.csv' file, placed in the main folder, pick only one
Neutral
frequency,raw
10,0.0
10500,0.0
15420,4.25
17620,16.25
23999,6.0
Warm
frequency,raw
10,0.0
80,0.0
130,0.25
220,0.25
330,0.0
1300,0.0
1575,-0.325
1900,0.0
2000,0.0
2400,0.0
2900,0.25
3200,0.25
3600,-0.25
4105,-1.2
6130,-1.5
7671,0.0
7771,0.0
8000,0.0
9000,0.0
10500,0.0
15420,4.25
17620,16.25
23999,6.0
Warmer
frequency,raw
10,0.0
80,0.0
130,0.5
220,0.5
330,0.0
1300,0.0
1575,-0.65
1900,0.0
2000,0.0
2400,0.0
2900,0.5
3200,0.5
3600,-0.5
4105,-2.4
6130,-3.0
7671,0.0
7771,0.0
8000,0.0
9000,0.0
10500,0.0
15420,4.25
17620,16.25
23999,6.0
Results of Harman target curve compensation (using RTings measurements), neutral EQ.
Warm results
Warmer results
Green thick line is Graphical/Convolution, thin is Parametric (N band), dotted is Fixed Band.
EDIT:
Found that installing EqualizerAPO as a LFX/GFX on Windows 10 caused distortion, notably around 7900Hz, installing as an SFX/EFX fixed it, sounds clean. Setting is in Troubleshooting options in the Configurator. Likely something internal with where the APO is placed in the Windows Audio stack, as SFX/MFX/EFX are full replacements for Vista-era LFX/GFX. Also, post-mix uses the EFX mode, which will disable all APO's but Equalizer APO. Pre-mix is broken for me so I just unticked it in the Configurator to only have the post-mix EFX APO installed.
EDIT:
I am content. Flat + EQ + all addons (incl semi diffuse-field), 3D Auto 7.1 with Room Reflections at 30, head settings inputted, watching Avatar and Godzilla, surreal. Best headphone cinema experience I've ever had, beats any prior surround solution or headphone. Halo 1 Anniversary on PC sounds amazing, crisp and clear with a great soundfield. Bannerlord as well, locality is spot on.
Note, when doing cross-comparison, replace your whole config.txt for volume matching with
Channel: ALL
Stage: post-mix
Preamp: -6 dB
EDIT:
Updated all profiles one last time, uses an altered base frequency response tuned to the F5 firmware update, leaving all profiles more accurate in terms of tuning the Mobius towards the Harman curve. Warm/Warmer is also more custom tuned now, with a slight restoration of 80-300KHz alongside tuning at 1.5KHz and 3.5KHz.
  • neutral_48_96KHz.zip
  • warm_48_96KHz.zip
  • warmer_48_96KHz.zip
May 22, 2020 at 8:27 PM Post #4,803 of 5,780
May 23, 2020 at 3:07 AM Post #4,805 of 5,780
May 24, 2020 at 3:28 AM Post #4,806 of 5,780
Are the gel pads deeper or more shallow than the original pads? With OG pads, the fabric covering the left driver I've noticed isnt atm very tense, I think its lost a bit of its tension. Might be due to my ear pushing against it, its hard to tell. Had a similar problem with the HD650. Right ear is still generally 'tense' in terms of the fabric.
May 24, 2020 at 7:10 AM Post #4,807 of 5,780
I think he wants the option. Don't we all want a lightweight closed back Audeze that can run passive or on active BT? I do.
That would probably be my perfect headphone
May 24, 2020 at 6:43 PM Post #4,808 of 5,780
It'd be great, but I care more about PC and gaming versatility with the awesome sound signatures it comes with for music it's by far the best gaming headset out there for the price; Some additions to the software, some tweaks to the hardware/firmware flashing(&recovery) and headset programming so we can program and take with our own EQ. Small things that allow us to dial in the headset perfect for each user beyond our head settings. For a first generation headset they did great, I just hope they don't churn out a V2 without a lot of added details and consideration on the build quality and people who wear headsets around their neck or off one ear due to work demands. I'd pay extra for metal parts on the yoke, easily replaceable battery, that makes it a buy it for life.
Gelpads are the same depth but do not lose form like the memory foam they wont compress as much or go flat. I've had them for a year i think now and they are the same shape as when I bought them and the memory foam look like squished and angled after only a few months of use for me. They just gotta ditch the foam and make the gelpads the standard even if it costs extra 10-15 dollars.
May 25, 2020 at 5:57 AM Post #4,810 of 5,780
Im not really a gamer but wondering these would be a decent portable option for black/death metal?
May 25, 2020 at 6:00 AM Post #4,811 of 5,780
Yup. I can attest to that. Both in wired and wireless, Metal is awesome for these cans along with my 3D gaming
May 25, 2020 at 2:11 PM Post #4,813 of 5,780
the headset is great for any genre of music, anything I've thrown at it, even live acoustic recorded in a church sounded amazing. I've not found a movie it couldn't take (tho I typically default to 5.1 external speakers) and games just depend on what you're playing for you to set audio. Is it a portable headset tho... maybe? it's not foldable like the LCD1, it's flexible but I don't think the build quality is perfectly suited for daily portable use, even tho they had this in mind, I don't think they nailed it at all, but I could be totally wrong and others should chime in on this. I'd only expect 1 year+ of life outta the headset if you're abusing it (stretching wide and lifting your headset by the cups is just 1 way) as mine didn't last more than that but I don't travel more than 500 miles a year and took great care with them I never bent or abused, never worn around the neck, always stored properly after use. I personally don't take cans I rely on daily for portable music but around the house the Mobius has been great.
May 25, 2020 at 5:24 PM Post #4,814 of 5,780
Is there any chance Aptx HD support can be added? All these codecs are free to my knowledge so was it just a time thing that caused it not to be added?
May 26, 2020 at 1:13 AM Post #4,815 of 5,780
Why do you need that codec? Android supports LDAC now which is better than AptX (HD) and on iOs there is only AAC...
Those codecs aren´t free also :wink:
I don´t see any reason for AptX HD now when you support LDAC. There may be a few transmitters that support AptX but no LDAC, but those are very few (old Android devices and I think Windows 10 supports AptX (no HD at the moment).
