- Mar 20, 2010
Well alcantara has more in common with velour in terms of comfort. It's a fabric. Thing is, they are much more dense and the inner lining in pleather, so it seals about as good as pleather, with similar sound.Are they as comfortable as velour?
Surprised they make such a difference from pleather.
I wouldn't say they are as comfortable as the softer velours out there, but they are definitely a step above pleather and leather to my ears.
Problem with full velour is that velour doesn't seal well and if headphones are made for better sealing pads like the Mobius, velour pads will make a negative impact on sound quality.
The 1540 pads clamp a bit much, so it's not all perfect. I'll try stretching it out a bit. I do have some Audeze vegan pads so I'll try those, though they are a bit too spongy. They are super comfy, but affect SQ IIRC. I miss the old LCD2 vegan pads which weren't as soft, but sealed well.
