I just bought the LCD-X! The 2021 update makes this a no brainer. This is my first “next level” set of cans, I can’t wait! I sure hope I can crank the volume and the treble doesn’t get too shrill
Audeze LCD-X
- Thread starter Icenine2
- Tags
- audeze-lcd-x
Lohb
Anyone have the latest X and latest LCD-3 for any bulletpoint comparisons....?
Looking at both just now.
I‘m quite treble sensitive and I like to play my 2021 LCD-X at high levels from time to time. Some recordings can sound shrill on them but that’s the fault of the recordings themselves (I like a lot of Metal music which can often have overtly hot treble)I just bought the LCD-X! The 2021 update makes this a no brainer. This is my first “next level” set of cans, I can’t wait! I sure hope I can crank the volume and the treble doesn’t get too shrill
But by and large they are quite neutral with no frequency range standing out above the others.
Good to know. I was thinking about going the ifi dac/amp route since I only do portable, and trying out the X-bass feature on those metal recordings that may be a bit shrill.I‘m quite treble sensitive and I like to play my 2021 LCD-X at high levels from time to time. Some recordings can sound shrill on them but that’s the fault of the recordings themselves (I like a lot of Metal music which can often have overtly hot treble)
I’ve heard good things about the Ifi anyhow
iFi micro iDSD black label and signature are both great options. Don’t forget to try out the firmware with the GTO filter option, it sounds amazing.
I had to send them back. I may have gotten a bad set. There was hardly any bass at all. Tried with 2 amps. EQ can only do so much. There just wasn’t much impact or slam.
sucks because for the price it has some really cool features, accessories and build quality. A hefty headphone like that you’d think would have some thunder
Golyatx
About to receive LCDX 2021 in about one hour! Cant wait. Coming from F. Clear.
mitchb
- May 13, 2007
Congratulations. Enjoy your new headphones.
For those who use Roon in your setup, do you use any type of Headroom Management? If so what?
mikecheck95
what are your impressions so far?About to receive LCDX 2021 in about one hour! Cant wait. Coming from F. Clear.
Golyatx
So far so good!what are your impressions so far?
Feeding it with RME ADI 2 DAC FS.
About to receive Burson Soloist 3XP next week. Cant wait for it!
shwnwllms
Ordered the LCD-X 2021 Creator’s Edition yesterday. For those who use Roon is the LCD-X preset sufficient or do I need to EQ on top of that?
Golyatx
They sound ok from box. Just add what you need. I added more bass ofc for shaking and slam. Old X preset is not for this X 2021.Ordered the LCD-X 2021 Creator’s Edition yesterday. For those who use Roon is the LCD-X preset sufficient or do I need to EQ on top of that?
mikecheck95
The Audeze Reveal presets are meant to be quite conservative just to bring all of their existing headphones to a similar target. If you want something more “conventionally neutral” you may need to use their parametric EQ. Resolve from Headphones.com has an EQ preset and there is video on Youtube showing how he got there.Ordered the LCD-X 2021 Creator’s Edition yesterday. For those who use Roon is the LCD-X preset sufficient or do I need to EQ on top of that?
looking at the measurements of the LCD-X you shouldn’t need much EQ at all if any.
Andii
Due to the revision, old presets no longer apply. The 2021 is good to go without eq.Ordered the LCD-X 2021 Creator’s Edition yesterday. For those who use Roon is the LCD-X preset sufficient or do I need to EQ on top of that?
Most presets or all presets out there will be boosting at 4k trying to counter the dip that was previously there, but no longer is.
I run mine with no eq at all and it aligns with my preferences.
If it doesn't align with yours, you would be better off actually making your own to suit your preference, which might be as simple as a bass shelf.
Total: 13 (members: 0, guests: 13)
