That's a bummer. But thanks for letting me know!They told me that they don't sell them and I'd have to send them in for$70 to get some new ones applied. Also, removing the grills voids warranty.
Audeze LCD-X
- Thread starter Icenine2
- Tags
- audeze-lcd-x
snip3r77
- May 13, 2010
I cant recommend the Lohb strap enough. I had hot spot issues as well. Now my LCD-X feel like I am using a nice leather sofa.
is the installation ez?
As pie. If you get it and have trouble, someone on here can help; even my little self.is the installation ez?
How is the stock balanced cable in comparison to Norne Solvine?
Why do I get the impression no one has even listened to the stock balanced cable?
sahmen
- Apr 6, 2014
I have listened to the stock balanced cable, but not the solvine... So I can't answer your question. On the other hand, I have used the LCD-X with the Norne Draug 2 and the Silvergarde S cables, all in balanced mode, and have preferred the Norne cables.
To be fair though, the stock Audeze balanced cable does not really sound "bad." I think it has a satisfactory and decent ability to represent the power and sound quality of any pairing of the LCD-X with any genuinely balanced amp. I remember disliking its looks and build more than the way it sounded. On the other hand, I had the Norne Cables ready when I got the Audeze, so I can't say I had the patience to listen to the stock cable long enough, and with enough attentiveness, to understand its strengths and weaknesses. I just never considered it worthwhile giving it that kind of listening time when the Norne cables were already available and waiting in the wings. My main interest was, and has been in enjoying the cans with the best cables I had on hand, rather than torturing myself with tedious cable comparisons and shootouts.
I can tell you for sure, however, that the stock balanced cable will give you better performance, as compared to the stock single-ended cable, on several balanced amps that offer both single-ended and balanced connectivity.
the finisher
I never used the stock balanced because I bought the creators pkg, with SE only.
Norne now is making Solve X adaptors so I can use my Solvine with other cans, very happy, as I only need 1 expensive balanced cable now.
http://www.norneaudio.com/litzheim/index.php?route=product/product&path=60&product_id=108
JeoO
Has anyone actually directly compared LCD X with newer driver vs older driver?
i now had 3 LCD X and actually the one with the new driver sounded worse than the other ones.
Did i just get a bad sample? How is your experience?
I wondered this as well. I have a much older X with thousands of hours on it and from reading others' reviews of much newer drivers, mine seems to possibly have more of the lush Audeze house sound whereas the newer drivers may be somewhat more neutral?
I may be fulla crap too on this not having heard an X with the new (2016+) drivers so whatever this is worth... Prolly not much.
My couple month old X's sound pretty great to me. Side by side with some other cans, they are certainly my warmest!I wondered this as well. I have a much older X with thousands of hours on it and from reading others' reviews of much newer drivers, mine seems to possibly have more of the lush Audeze house sound whereas the newer drivers may be somewhat more neutral?
thecrow
- Oct 18, 2014
Can you give us your opinion of the draug 3 v silvergade on the lcdx?I have listened to the stock balanced cable, but not the solvine... So I can't answer your question. On the other hand, I have used the LCD-X with the Norne Draug 2 and the Silvergarde S cables, all in balanced mode, and have preferred the Norne cables.
I recently bought the silver draug for the lcd2 but i don’t think it’s the best match for me. I am going to order a norne copper cable (probably volsund) but i was curious on how the silvergarde would match (relative to copper). I have had the s2 previously eith my hd800
336881
- Jul 19, 2012
There is no feedback on a planar headphone. The Lcd-X is a planar. Unless you have a problem with the stock cables looks or ergonomics there is no reason for an aftermarket cable.
Beg to respectfully disagree. However, I'm using SE, and I found each cable upgrade to be just that.There is no feedback on a planar headphone. The Lcd-X is a planar. Unless you have a problem with the stock cables looks or ergonomics there is no reason for an aftermarket cable.
I am using a SE Norne Audio Solvine with my X and it sounds mighty nice! =^)
sahmen
- Apr 6, 2014
Well this is interesting, because I also prefer the pairing of the draug 2 and 3 with the LCD-X to the pairing involving the pure silver silvergarde S, which matches a lot better with my Hifiman He-1000. Each time I have tried the Silvergarde with the LCD-X, I have found myself going back to the Draug after less than 5 minutes. I have heard people here praising the pairing of the Solvines (Silver/Copper) with the LCD-X, but I cannot personally say anything about that as I have never tried that. I also have a Volsund order in the works for the LCD-X involving a Silver/Copper combo of wires, on the recommendation of Trevor, so I guess we shall see how well that does with the LCD-X, once that cable arrives.
To be fair, I have never given the Silvergarde S/LCD-X pairing any significantly lengthy listening time, in order to properly nail down exactly what I like or dislike in the sound signature. I wish things were different, as I am curious to find out if I can grow to enjoy that pairing in the way others seem to (I have heard some people praising the pairing of the silver Draug and the LCD series headphones)... In practice, however, I have always followed my visceral reactions in defaulting to my preference for the copper draugs. It probably has something to do with system synergy, but again, I have had more pleasing experiences pairing the Silvergarde S with the He-1000. I'm hoping the silver/copper volsund will make for a better synergy with the LCD-X in my system.
Total: 6 (members: 0, guests: 6)
