Are you in the US? If so, choose 120V. 240V is for Euopean countries with 240V electical outlets. Multibit is a must, IMO, the only reason to buy Schiit DACs. As far as tubes vs solid state on MJ2, I would get both just to satisfy your curiousity.
Audeze LCD-X
- Thread starter Icenine2
- Tags
- audeze-lcd-x
Yes, I am in the US. I think I am all set then, 115 V for both, Gumby multibit with MJ2 solid state & tubes. Thank you Senpai!!
Matias
Here is a topic about the Ursine Audio cables and a picture of the braided cable that I ordered.
https://www.head-fi.org/f/threads/ursine-audio.850068/
Is it normal to hear a slight hollowness in the vocals? Probably around the low mids. Or is this isolated to my pair?
I dont exactly hear any hollowness in low mids. Is it your amp may be? What are you running on?Is it normal to hear a slight hollowness in the vocals? Probably around the low mids. Or is this isolated to my pair?
I received my LCD-X and currently burning in. For now running on IDSD BL Edition, and loving it. Specially 3D+ and XBass function in the amp are adding flavor to already amazing LCD-X.
I have a question for you experienced guys out there. As it stands right now I could purchase both Gungnir/Mjolnir 2 or I could purchase either the Ragnarok or Yggdrasil only and have to wait 2-3 months to purchase the other. I don't want to update my gears for a little bit atleast after that. Also curious as to how much I would hate running either the Yggy or Ragnarok with a Modi 2 or Magni 2 (current owns) for a couple of months or what to expect from doing something like that.
Current cans HD650, HD700, HD800 and LCD-X
Current Gears: ifi IDSD BL, Magni 2 and Modi 2.
Any input would be appreciated.
johnzz4
May want to consider the Audio-gd Master 11. Great DAC and amp combo for less than the Yggy alone. Excellent value.I received my LCD-X and currently burning in. For now running on IDSD BL Edition, and loving it. Specially 3D+ and XBass function in the amp are adding flavor to already amazing LCD-X.
I have the M11 and the Yggy/ Wells Milo. The M11 isn't far off at all.
Thanks for the recommendation. Some people say buy different units like DAC separate from AMP. Would you say Audio-gd master by itself would do the job? Sorry I am kinda new in high end gear so not familiar with amp and dac that much. Will it go well along with both HD800 and LCD-X?
johnzz4
Yes, just the M11 by itself.. and it has tons of connections so you can use it as a DAC or amp later on if you want. It's big though, so make sure you have the space.Thanks for the recommendation. Some people say buy different units like DAC separate from AMP. Would you say Audio-gd master by itself would do the job?
One more question, would you recommend tube amp with LCD-X like MJ-2 or any other? I hear its not a good fit with HD800, correct me if I am wrong.
johnzz4
I never got into tubes, but the R2R dacs (which the M11 has) are known to be smooth and without glare.One more question, would you recommend tube amp with LCD-X like MJ-2 or any other? I hear its not a good fit with HD800, correct me if I am wrong.
What I like with MJ2 is to be able to use it as a SS amp or as a Tube amp. I have it and I put the tube I want in it (or LSST).One more question, would you recommend tube amp with LCD-X like MJ-2 or any other? I hear its not a good fit with HD800, correct me if I am wrong.
NFB-28. So it has nothing to do with power. I requested the FR graph and noticed a huge dip at 3k. I think that contributes a lot to the hollowness. Guess I got a crappy pair of LCD-X's.I dont exactly hear any hollowness in low mids. Is it your amp may be? What are you running on?
336881
- Jul 19, 2012
Apex peak/volcano or sangaku.
CarlosUnchained
I can tell about Lyr 2. The pairing is really good, it adds a bit warmth but nothing overwhelming. I didn't pull the trigger on it yet, also considering iDSD BL among others.
How do you compare the Schiit stack against the Black Label?
If you get Schiit's tubes please compare it with the iDSD!
Total: 15 (members: 0, guests: 15)
