SMG52
- Dec 24, 2011
When driven by THE RIGHT amp YOU WILL NOTICE THE DIFFERENCE!!! No question about it.
I'm interested to read about all of your amp/LCD-X pairings.
I'm also going to have to disagree that the LCD-X is more detailed than the HD800 (or even on the same level). I've been comparing the two closely for a few weeks now, and it's not even close, IMO. The HD800 extracts much more micro-detail -- you get so much more texture and ambiance from the recording than the LCD-X.
It's odd though, although the HD800 is more detailed, the LCD-X is less forgiving of bad recordings (counter-intuitively, I know). It's mostly due to the fact that the LCD-X treble is rougher and less-refined. Although the HD800 has that troublesome 6K peak, the treble rendering is much sweeter and smoother overall. I've found myself cycling through music trying to see what recordings are good enough, as I'm also finding that the LCD-3 is "brutal" with less-than-perfect ones. There's definitely some wonkiness going on that I'm having trouble putting my finger on.
Looks like you are bringing in the big bad boys for battle. By the way, I use the Philips rectifier that is sold at Upscale Audio...I have the RCA5yGT and the Philips beats it by a mile (based on my taste), even though the RCA is fine (i.e., it would be the best if the Philips did not exist!). The RCA is warmer and punchier...the Philips is airy and opens the soundstage, which works wonders for Classical Music, which I almost exclusively listen to). Both are great, but the thing is that I prefer airy with bigger soundstage. You are gonna have so much fun rolling tubes!!! By the way, my current tubes are the Philips rectifier, two EL84 Tungsram tubes (the best EL84s I've heard, again courtesy of Upscale Audio), and a GE5751 five star (black plates, 1957) driver tube. My god, the sounds this makes with the T1 are just unbelievable.
Actually, I'd particularly be interested in how close your Burson Soloist comes to the Dark Star driving the LCD-X, as it's more in the realm of possibilities for me. Also, any experience with the Woo Audio WA6 SE? Although I am trying to steer away from tubes, having had many tube amps for my hi fi and knowing how neurotic I can get with tube swapping.
Now, here we go again with the LCD-Xs, but now being driven (single ended) by the Decware Taboo. My taboo is the SE84TS (from about two to three years ago), not the newer version. This one uses the 12AX7/12AT7/12AU7/5751 variant tubes at the input stage; the new version uses the 6922 tube at the input stage (i.e., I am thinking that the newer version is better sounding than mine since I love the 6922 tubes and I've never been to0 crazy with the 12AX7 et al tubes). So, I tried various tubes and I always got similar results. To put it bluntly, the Taboo is unable to take the LCD-Xs to the lofty heights of Mount Olympus. I don't think the problem is with the Taboo itself...rather, it is a problem of using a tube amplifier, period! The problem is that once you tube-it-up, so to speak, with the LCD-Xs, the sound is no longer as tight, pristine, dynamic, and awe-inspiring as it was with the powerful solid-state Ray Samuels Darkstar. Okay, so they don't sound awful either, but suddenly the Audezes no longer stand head-and-shoulders above the other flagships, but rather, it starts to sound closer in quality to the HD800s and T1s of the world...suddenly it has become a horse race and one is left undecided as to which of the three is the best of the of the bunch. Moreover, the Audezes have always had a magic of their own in the mid range...adding more wetness and cream in that area of the spectrum via tubes is like gilding the lily...I truly consider it to be unnecessary and crossing the line into being "too lush" for its own good. Out of the Taboo the sound is more diffuse, warmer...in a word, more LCD-2-like in quality of sound.
I am starting to think now that the way to go with the LCD-Xs is by using a powerful solid state amp. I am thinking that the Burson Soloist (4 watts, it I remember correctly) and the EF-6 (which are obviously much cheaper than my Darkstar) are going to do quite a job with the LCD-Xs. Since I have both in my headamp stable, I shall report how they perform with the Audezes within a couple of days. While efficient, my ears are telling me that lean and mean (as is clear-as-a-whistle, high-powered solid state) is the way to go with the LCD-Xs. Although it may ultimately be that the Darkstar is better than the Soloist and EF-6, I have the suspicion that such is not going to be the case...it is probably a matter of pure power (or current, I don't know which of the two) rather than high cost that will likely prevail in this case. The magic that I have experienced with the Darkstar is just not there (maybe 85% of it) with the Taboo. Oh, I also have to consider that the Darkstar is fully balanced...that may ultimately be the reason (maybe not) why the LCD-Xs sound so good out of the Darkstar. I played the Audezes with the Darkstar again right after driving then with the Taboo and the difference is not subtle...it is clearly patent. I used brighter-sounding, neutral-sounding, and darker sounding tubes, but nothing really worked the way I wanted...I was always left lusting for the sound that the LCD-X and the Darkstar make. I still have plenty of amps to play with, so we'll see how things turn out. So, all in all, kinda disappointed with the Taboo in this one, even though it plays most of my other headphones superbly.
Kinda sums up my experiences with orthos and the tube amps I've heard them with. I've always gravitated towards SS amps for orthos....and I'm a long time tube guy (or used to be).
Peter have you tried any of the non-tubey sounding amps? BA, Stratus, etc.
I'm now seriously considering the LCD-X if the HE-6 doesn't please me once modded. If I end up trying them, I'm thinking the Stratus might be a dream pairing, could be wrong.
I've tried a WA6SE which is fairly non-tubey and a Zana Deux (with the LCD-2s).
Anyone driving the LCD-X with Mjolnir/Gungnir?
The Gungnir/Mjolnir is my main setup with the LCD-X and I love it. I'll be the first to admit the G/M is not the best pairing with brighter headphones, but it seems to be magic with everything Audeze. The LCD-X sounds powerful and detailed out of the G/M with a surprisingly large and airy soundstage. I haven't found any issues with sibilance or treble harshness. A nice complement to the Mjolnir is the new Vali. I have both the Mjolnir and Vali being fed by the Gungnir. The Vali offers a more intimate soundstage with a live performance signature--a touch of reverb and a controlled analog sound.
Tubes with the LCD2s? Oy vey...pure slush!
The LCD-2 and the X sound great on my DNA Stratus. No slush with the 2's, at times I found myself thinking I was listening to my HD800's when in fact it was the LCD2.
