Audeze LCD-X
- Thread starter Icenine2
- Tags
- audeze-lcd-x
- Dec 14, 2010
How do they sound with the WA22 and what is that tube complement?
DarknightDK
- Sep 25, 2011
Tubes on the WA22 looks about right.
GalaxyGuy
- Feb 21, 2013
Using WE421a power tubes, TS 6F8G drivers and a UE 596 rectifier. A very nice combo. I just received a WE422a rectifier; we'll see how it sounds soon enough.
When comparing the HD800s with the LCD-X, I have been finding that I prefer the LCDs just a tiny bit over the 800s. That is, I maybe prefer the LCDs 7 out of 10 times to the 800s. Both sound fantastic with the WA22, to be sure. I feel fortunate to have the setup that I do.
- Oct 22, 2011
You have a really nice rig GalaxyGuy. M51 + WA22 -> X/HD800:
songmic
Very nice setup, but don't you think it's a tad unsafe to place the WA22 on top of an NAD M51? The WA22 weighs almost twice as much as an NAD M51. It could also affect the performance of either gear. Just saying...
Icenine2
Mac..........please post the pictures of your Bryston>Headamp GS-X mkII>LCDX............
Dubstep Girl
yes!!!1
im using the same combo right now on the Glenn OTL amp i'm borrowing and i love it!!!
the WE421A, 422A, TS 6F8G is probably one of the best tube combos i've heard. you are going to love the 422a!
- Jun 15, 2012
yes!!!1
can the WE422a be got easily, seems i cant find it.
dan.gheorghe
- Mar 15, 2010
I just got these. Coming from hd650s - using a burson 160ds amp. Recently upgraded my amp and was surprised how much better it sounded compared to my old one (audio-gd compass). So I decided had to upgrade my headphones.
The 8 foot cable length is not good. What aftermarket cables would you guys recommend? what material?
As I said in the review, I use Toxic Silver Widow with the X and I get sonic improvements as well besides the awesome looks.
I have used the Toxic Silver Widow with LCD-X and I found to be a very good match for it, as it puts you a little further in the scene. It actually relaxes the treble a little more but gives it more extension and detail, improves the bass impact and makes it faster, the instrument separation is better and the sound is more detailed overall.
OMG. Thank you. Got any recos for church organ music?
Best -
RCBinTN
No problem. I may have something but I have to search for them and organize my music . ( I am kind of unorganized ).
Dubstep Girl
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=western+electric+422a&rt=nc&LH_PrefLoc=0
figaro69
- Dec 1, 2012
LCD-X with Silver vs. Copper replacement headphone cable? I'm thinking silver (since I listen primarily to classical music), but I'm not sure.
GalaxyGuy
- Feb 21, 2013
The case of the M51 is relatively (like 3/32 or so) thick metal. Feels like steel to me, but I guess it could be aluminum. At any rate, it seems plenty sturdy enough o support the weight of the 22. In terms of affecting the performance of the two, I wasn't able to notice the difference between having them set side-by-side and having the amp on top of the DAC. The metal case surrounding the DAC should shield the internal components from any transient EM waves that leak from the amps transformers, provided that each component is properly grounded and isolated. I have each component plugged into an isolation transformer, which should shield them from any transients in the line signal. As such, I am not too worried about a degradation in the performance by having them stacked. It is true that the transformers in the amp could, in theory, generate induced currents in the chassis of the DAC, but since it's grounded I don't think it should be able to affect the internal components. If anyone out there has any info in this regard, I'd be more than happy to hear it, though. I could certainly be dead wrong, and I don't have a electrical engineer's insight into the behavior of AC transients.
GalaxyGuy
- Feb 21, 2013
PS I needed to reclaim some of my desk space!
- Jun 15, 2012
**** that. they can keep it. Did you pay that much for yours?
