Apr 26, 2022 at 5:39 AM Post #5,101 of 7,074
I also had the infamous hum with Playmate 2. This time, however, the solution was very simple, as the others have also described: Connect RCA ground with earth. Done.
Apr 27, 2022 at 9:43 PM Post #5,102 of 7,074
How do you know if you have the newer/larger headband for the LCD-5? Mine measures 10 1/4 inches following the headband from one end to the other.
Apr 27, 2022 at 9:55 PM Post #5,103 of 7,074
Apr 27, 2022 at 10:15 PM Post #5,104 of 7,074
Thank you very much for the link.
I have had these for a few days and wow am I enjoying the clarity and resolution!
Now I need to figure out if I want to keep my VC or not. The smoothness of the VC takes a bit to get used to when going directly from the LCD-5 :)
Apr 27, 2022 at 11:15 PM Post #5,105 of 7,074
They are identical in size and dimension. Differ only in the spring / clamp applied
Apr 29, 2022 at 1:11 AM Post #5,106 of 7,074
When the alarm clock rings an hour earlier, so you can listen to music before work.🤝
#LCD-5isaddictive
Apr 29, 2022 at 2:42 PM Post #5,108 of 7,074
I never thought I'd travel with the LCD-5 but after pairing with the Hugo 2... Wow! It's fantastic, I can see taking this combo on road trips. :)
If you take the Pelican case people will think you are carrying firearms :beyersmile:
Apr 29, 2022 at 3:38 PM Post #5,110 of 7,074
This track was the first time I felt the bass in my body with headphones.
I mean that completely seriously.
There were parts in my neck that vibrated with the bass...😬👌
Apr 29, 2022 at 6:00 PM Post #5,111 of 7,074
Nice!🎧🎶
Apr 30, 2022 at 12:56 AM Post #5,112 of 7,074
Apr 30, 2022 at 3:09 PM Post #5,113 of 7,074
Apr 30, 2022 at 6:10 PM Post #5,114 of 7,074
Apr 30, 2022 at 7:40 PM Post #5,115 of 7,074
go to the audio science site where you will be told measurements say it is the best HP amp available and better than amps 20 times more expensive
