I have been listening to my more difficult to drive HPs on this amplifier from SAEQ called Hyperion Ge. This is a loaner courtesy of the kindness of Wilson from Jaben SG. Wilson brought in the entire range of amplifiers from SAEQ (as well as their interconnects). I have been sharing my impressions as it is not always easy to find an amplifier that will drive the HPs whilst being enjoyable: lush yet highly detailed.
The SAEQ (Serbian Audio Equipment) is owned by Dragaon Domanovic. He is also the main designer. I originally came across SAEQ because of direct drive amplifiers that they designed and built to drive RAAL Requisite ribbon HPs. So, when i went to collect my HSA-1c (which drives both ribbon HPs as well as planar and dynamic HPs), and Wilson suggested I give the the Hyperion Ge, I jumped on the opportunity to try it out since I had read about the Hyperion Ge on this review:
https://www.hifi-advice.com/blog/am...ws/saeq-hyperion-ge-and-raal-requisite-ca-1a/
A HP amp which can also drive speakers?! Wow! Most audiophiles will use speaker amps to drive HPs but this is the first time I have heard of a HP amp which is powerful enough to drive speakers.
I read more about the Ge: Dragan wanted to use Germanium transistors which would give a lush signature whilst still being realistic and detailed. Germanium was used between the 1950s and 1970s and abandoned because it was too expensive for mass production.
Anyway, after spending some time with the Ge. Through the attenuated output as well as the direct output. Each seems to have slightly different tonality. The attenuated output seems to be sweeter. I am enjoying the effortless sound signature of the Ge on the LCD4. It does make the LCD4 sound any warmer but does allow through great details and nuances.
Well, if you are in Singapore, you are in luck! Because Jaben SG has this in stock. I shall also be trying out the PDA-1b and the Morpheus, both of which have attenuated output and direct out put as options. Exciting times ahead!
