Zoom25
- Nov 24, 2011
After more listening, I’d put the comfort of these headphones into the “bearable” category. Definitely still causes headaches after some time wearing them, but no neck issues (though I’ve never had neck issues with an Audeze headphone). It’s certainly more comfortable than their old headband (which to be honest was an ergonomic nightmare). The headband strap gets within a millimeter of touching the metal part (or depending on how you wear it it does touch the metal part) which makes me worried that the pleather may stretch over time and make them less comfortable, putting all the weight of the headphones onto the tip top of your head. They may be more comfortable than the old LCDs, but they’re no HD800 or 99 Classics in the comfort department. More padding on the strap and more space between the strap and metal piece would certainly be welcome changes to the rev 2 of this headband (take a long hard look at the 99 classic headband, that’s how you make a comfy headband!). These will likely be relegated to bedtime use rather than daytime use because the comfort is not up to par.
Despite all that, this is a huge step for Audeze, and is very close to what I was asking for years ago.
Well put regarding the comfort and how the pleather headband suspension responds to the metal headband on top. I've been playing around with it to get it more comfortable.
It's a shame since these get a lot right sound wise. Decisions, decisions.
