Hi guys
I received the LCD-2C a few days ago. I already own a LCD-2 (late 2016 Fazor), here are my impressions (I run them on an Audio-GD NFB11.28).
2 pics here :
https://imgur.com/a/ZbcbZFT
Build / Comfort :
- Feels more solid / sturdy in the hands than the wooden Fazor
- Is only 35g lighter than the Fazor (545g for the LCD-2C, 580g for the Fazor Shedua), I measured them on my food scale without cables. The Bamboo Fazor is probably lighter.
- Comfort is not that better : the headband is much better and distributes well weight. But there is a difference in the pads (look my second pic) : the pads of the Classic are quite thicker than the lambskin pads of the Fazor. Maybe 0.5-0.7cm difference in thickness. As a result, I have more pressure around the ears compared to the Fazor. Also the lambskin pads are softer. Since I use a wool headband on my Fazor (which helps for any hotstop on top of the head), I'd say the comfort is very similar for both headphones (for me).
- You can see that the black nylon rings of the Classic are thinner than the wooden rings of the LCD-2F. My guess is that Audeze probably made the rings thinner to compensate the thicker pads.
- The braided cable is easier to manipulate and the Y finish of better quality, but I've never had issue with the ribbon cable of the Fazor.
- The packaging, I guess most people know that the Pelican hard case is absent with the Classic.
Sound
- I find them to sound different in tone / frequency response, but they are overall close in detail retrieval, speed, imaging and soundstage.
- The thing that surprised me the most is the bass : both have a similar impact. The bass is tight and perfectly extended, without any additional slam or midbass impact. From comments, I was expecting maybe
a bit more power from the Classic. I even made a test where I powered the Classic to my NFB11 (an amp with plenty of power for them), and the Fazor to my Fostex HP-A4 (a small USB-powered amp that gives
10 times less power than the NFB). The results quite surprised me : even underpowered, the Fazor slams as much as the Classic.
- The midrange and treble are different from one to another.
- The midrange of the Fazor is rich and forward (relatively to the Classic) with enough energy for jazz or female vocals. The LCD-2C midrange is more laid-back, a bit more liquid/smooth. And yes, the upper-midrange
is a bit more dipped than the Fazor.
- While I find the mids of the Classic very laid-back, sometimes they sound a bit slow to me, but I must not be wrong ; the Classic is very resolving can, it's just that the overall response is very smooth.
- Same thing for the treble, the Fazor has much more upper-treble (above 10 khz) as well as mid-treble. Both are overall recessed in the lower-treble.
- Soundstage and speed are about the same, sometimes I find the Classic to have a better sense of depth because of the more dipped middle and upper midrange.
Overall I like both of them. I see the LCD2-F as an allrounder with a touch of warmth, whereas the LCD-2C is the more coloured laid-back variant, because of the more recessed clarity/presence region.
I made a comparison of the 2 LCD with other "warm" headphones here :
https://www.reddit.com/r/headphones/comments/8jd8u4/comparison_of_warm_open_cans_hd650_nighthawks/
