Tooros
- Mar 8, 2010
Just got mine from Frank - absolutely spot on.
PleaZe provide details of items purchased and from where, as I would like to do the same
2 mins trimming with a pair of scissors and a junior hacksaw and they’re made to measure and ‘weightless’
I messaged @Frank88 on here. He's awesome and extremely helpful.
I bought two of these (available in packs on 10 from AliExpress if you can wait - for the same cost as two from eBay)
https://www.ebay.co.uk/itm/2x-Replacement-Spare-Earhook-Ear-Hook-Loop-Earloop-Clip-For-Bluetooth-Headset/253335543895?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
You pull out the supplied circular clip and insert the new one from frank. I trimmed off 5mm from the stem of the clip and the associated silicone ear clip (after trying) to get the perfect fit. (You may not need to - depends on your head/ear.)
Hope that helps.
Anybody know how much headroom adjustment (preamplication) I should be using with the roon isine 20 eq preset?
You adjust this setting based on your highest gain setting in your eq. You use it to make sure nothing goes above 0db which can cause distortion.
For example on my eq below: You can see my highest gain is 7.5db on filter 4, so to be safe I have turned my pre-amp down to -8.5.
If nothing in your eq goes higher than 0db than you would not need to turn it down.
Many eq apps these days automatically compensate and adjust the pre-amp down automatically.
Preamp: -8.5 dB
Filter 1: ON LS Fc 120 Hz Gain 2.5 dB
Filter 2: ON PK Fc 250 Hz Gain -3.5 dB Q 1
Filter 3: ON PK Fc 1000 Hz Gain -8.5 dB Q 1.5
Filter 4: ON PK Fc 4000 Hz Gain 7.5 dB Q .4
Have you tried the Audeze Reveal on the Isine20's? I recently bit the bullet and bought a pair of LCD2C's for desktop use and used the reveal plugin and it's quite pleasing to the ears. Still need to try the reveal isine20 setting vs your eq settings which are still what I use full time.
Audeze's reveal plugin is a plugin you install into EQ APO and you use the anologue cable. It adjusts the eq to what Audeze feels is the best settings for each headphone. You even select the exact headphone you have inside the plugin. So far I like it a lot on the lcd2-c.
