Quarzer
- Feb 28, 2017
Just lay them on top of each other to be sure. The larger ear hooks are slightly rubberised (matt finish) compared to the smaller black ones which are very glossy plastic
I would lay them out if I was at home right now. But right now, the ones that came with the Apple model were not rubber, so I assume they are the same size.
Edit: they are indeed the same size.
That explains. Apple edition doesnt have the Large rubberized ear hooks.
Will Noble Audio iems cable work with Audeze isine?. They both take 0.78mm 2 pin. Can someone Clarify?. Thanks
I too use a DIY coupler for IEM measurements. It differs from @crinacle's setup but shares some of it's shortcomings. With my setup the iSine 20 shows a similar 1.5 kHz peak which I think is not representative of the real world frequency response, especially as Innerfidelity's measurements don't show such a feature. So I newer published my iSine 20 measurement.
@KMann: It would be very helpful if Audeze could provide measurements of the i-series to clear things up. I assume you guys use nice IEC 60318-4 compliant gear, that would provide a much better reliability than our DIY setups do. Also, a reliable measurement will help many people with their EQ-experiments.
Are you familiar with REW? You could load the FR, type in your EQ settings an REW will show you the outcome.This would be easier if I could measure the isine 20's everytime I made changes.
Hi!Are you familiar with REW? You could load the FR, type in your EQ settings an REW will show you the outcome.
That would be great! ThanksI could send you a PM with innerfidelity's digitalized RAW measurements that can be used with REW, if you like.
Some more EQ options
Since I see a number of Head-fiers using the EQ I posted and also saw some feedback on the EQ, I am happy to post two more variations that go easy near 4k. I would be happy to hear feed-back form you and we can even push the EQ to Cipher at a later point.
Here are two variants (V1, V2) and finally the original I had published earlier.
