-rowan-
- Oct 21, 2015
Oh yeah... Tubey goodness.
Nice! I like the whiff of Stax in there.
I will let you know how I get on. Many thanks.The cheap headphones are very easy to open up. Remove the foam cushions, open up, remove drivers. After that you can use a knife to cut out the ball pivot. I used a small wire cutter to cut it out. The plastic is very soft, you can even use scissors. After cutting a little sanding may be needed to smooth over the cutting.
The "A" logo on the isine has double sided tape underneath. I used the tip of a small hobby knife and gentle push in the edge while slowly lifting. A good place to put the knife tip would be the top of the "A". There is a notch on the back that I think is for alignment. Save the Audeze logo to reverse the mod or glue to the outside of the headband.
Sorry if this headband mod has hi-jacked this thread.
Just to help those interested.
Driver will pop out with just your finger nails.
Yank the driver off the cable and remove the ball pivot. Throw away the driver, total crap.
I used small wire cutters to remove the ball then clean up with scissors. The plastic is soft enough to use scissors only if you do not have small wire cutters.
Under the ball there is a flat support that extends lower than the circle. If you use thin double sided tape you will have to cut or sand that flush with the circle. If you use thick foam double side tape you can cut a round piece of tape in half, two semi-circles to go on either sides of that protrusion. Hot glue is the easier and quicker option. Just remember to make sure that the protrusion is glued in horizontally on your isine because there is a horizontal slot in the socket of the headband.
the on ear hooks in the groovy kit are very good not sure why this mod would be needed
For me the donor headphone is very cheap and everything done to the isine can be undone. Just remove the double sided tape or hot glue and glue the Audeze logo back on. You can still use the ear hooks anytime by just popping the isine off the headband and vise versa.I got nervous just by watching the photos of this DIY mod lol
I use the iSINE 20 with the ear hooks, and am very happy, but for the cost, the headband mod is cheap and easily reversed. For me,well worth a try.the on ear hooks in the groovy kit are very good not sure why this mod would be needed
Got the iSINE 20 yesterday, but could not get it to fit in my ear at all... The bore is really big. Are these supposed to be shallow fitting like the 1MORE IEMs? I could get a seal with those using the large tips, but I can't get any seal with these with any tips. And none of my spinfits fit at all...
So. i am happy to say that my i10s have really grown on me (to the degree that i haven't used my LCD-2s for a few days); however, the same can not be said for the cable. I have never experienced a headphone/iem cable as bad as this in my life. The thin cable may have been a nice idea, but is horrid in practice. It is stiff and constantly gets in the way, and half the time sticks out in front of my face, because i have to use the clip to keep em on me. Priority #1 is to find a good, cheap set of replacement cables; i would love the DIY route, but i have neither the tools nor the time (let alone skill) to make them.
