Bought a iPod Touch and a Cipher cable for the iSine20 today so I can see what all the hype is about. The iSine20 does sound absolutely amazing with the HM901, which lately is my main go to.
Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
- Thread starter Madcat207
Wish some of you would stop saying spinfits don't fit. They do, it's not easy to put it on for a fresh new outta box, but once you get used to the motion, and you're using it, it' easy to. I've used both the grey smoked dome / red stems and the grey smoked dome with fuchsia stemmed spinfits (XS sized).
how about these?Yes! My sentiments exactly. Venture Electronics do a mean cable for something like $15, *much* softer and more flexible than stock. It's also a bit brighter and drier imo. I'm personally fine with it but ymmv as always.
(And yes that's the level I listen at, with this beast.)
If this interests anyone, go to www.veclan.com, look for 'basic cable' and select the 0.78mm 2-pin straight connector.
And if anyone knows of other decent, inexpensive cables I'd be interested too.
https://www.amazon.com/NICEHCK-KZ-D...8&qid=1501639501&sr=8-2&keywords=0.78mm+cable
https://www.amazon.com/4-pole-Balan...8&qid=1501639501&sr=8-1&keywords=0.78mm+cable
-rowan-
- Oct 21, 2015
I actually have the first one, to replace the horribly microphonic stock cable that comes with most or all KZ IEMs. The pins on the connector are recessed so they won't fit the iSine. Haven't tried the second.
Anyone tried any other cheap, good cables?
- Dec 20, 2010
@Audeze Do you sell just the 3.5mm or cipher cable?
Riley Beale
- Jul 9, 2016
I believe Audeze said earlier in this thread that they are working on it. The Cipher Cable might be due to Apple proprietary restrictions. I know Apple has a lot of control over their own stuff. i believe you can get aftermarket 3.5 mm cables though. Thank you howdy. I forgot about that when I originally posted this.
Cheers
Riley
Check out moon audio.@Audeze Do you sell just the 3.5mm or cipher cable?
3.5 mm, yes - Since all the iSine users are under warranty, we haven't started selling cables separately. Cipher, we cannot sell them separately at the moment and can sell them only with our headphones.@Audeze Do you sell just the 3.5mm or cipher cable?
Stay updated on Audeze at their sponsor profile on Head-Fi.
hotteen
- Aug 22, 2014
@Audeze I need a replacement 3.5mm cable for my iSine 10 (the jack is loose) and since all iSine users are s under warranty as you said, would I be able to get one by sending mine in? I don't have a receipt, though.
Yes. Please contact support@audeze and they should be able to help you with it.@Audeze I need a replacement 3.5mm cable for my iSine 10 (the jack is loose) and since all iSine users are s under warranty as you said, would I be able to get one by sending mine in? I don't have a receipt, though.
How does Moon Audio sell them? I just bought one from there yesterday.3.5 mm, yes - Since all the iSine users are under warranty, we haven't started selling cables separately. Cipher, we cannot sell them separately at the moment and can sell them only with our headphones.
Thanks for letting us know. We will contact them.
Kevinb0127
- Mar 15, 2015
I apologize in advance if this has been asked and answered. Tried to search but skills are lacking Just got he ISine 20. Was trying to play hi res files (Onkyo player) via Cypher cable. They seem to top out at 48. Is that a limitation of the Cypher cable DAC or user error? Thanks in advance.
i believe that's Apple's limitationI apologize in advance if this has been asked and answered. Tried to search but skills are lacking Just got he ISine 20. Was trying to play hi res files (Onkyo player) via Cypher cable. They seem to top out at 48. Is that a limitation of the Cypher cable DAC or user error? Thanks in advance.
Kevinb0127
- Mar 15, 2015
I have another DAC/amp that I use with the phone that will play at the true resolution using the Onkyo player so that's why I was wondering if it was a Cipher limitation.
Agreed that stock Apple output is 48 unless you go out the Lightning port into something that can handle it.
Total: 7 (members: 0, guests: 7)
