Hello from a first time poster! Thank you for a great review. I'm looking to "up my game " in the headphone dept. I started with the p5s and also own the psb 4mu2. I had both of these headphones that you reviewed on my shortlist. Should I go open back el8? Closed pm3 ? I would not like to be too redundant with what I have. Any recommendations would be appreciated. Go easy on a newbie !!
depends on your budget, primarily applications, and whether you are interested in purchasing additional components (such as amplifiers/dac).
If you want an all-rounder headphone to be used with portable usage as well that is a sonic upgrade (do note that despite being a sonic upgrade, it is important to demo or read about headphones you are interested in as the sound signature/frequency response[aka amount of bass, mid, and treble] must match what you are looking for), you should be looking at closed options. My personal recommendations for more neutral-oriented closed backs that I really enjoyed include the $400 PM-3, sub-$200 AKG K545, $300 HP50, and $150-$350 Momentum (either gen1/gen2). People have been saying great things about the $400 BO H6 as well, but I haven't had a chance to try them. For slightly colored closed backs, you can check out the M100 for a bass heavy v-shaped pair of headphones or the MDR-1R/MDR-1A for a mid-focused pair of headphones. There is no need to spend more than $200-$300 for a solid all-around pair of closed headphones... as you go further beyond that price point you will begin experiencing more & more extreme diminishing returns, but the premium may be worth it for you. My two favorites closed headphones right now are the K545 and PM-3.
If you want to get as much sound quality improvement for your money as possible and are not planning on using them for portable usage or have another dedicated portable pair of headphones already, you should look into an open pair of headphones for home usage. Open headphones will leak sound in & out, but provide a larger sound stage & a more natural sound. do note that the majority of open headphones will require a amplifier at least & a dac optional to maximize your headphone's potential.
There are a multitude of amazing performing open headphones at many different price points from $200-$500 that perform very competitively against much higher valued options or flagship type headphones. My favorite for sound:value is the AKG K7xx from massdrop.com. The some of the classic highly regarded recommendations that outperform their asking price would include the following: Beyerdynamic has the dt770/880/990, AKG has the Q701, K702, K612 pro, K712, Sennheiser has the classic HD600/HD650, Phillips has the X1/X2, and Hifiman has the old HE-400, new HE-400i off the top of my head. Do note they all have significant variations in sound signature, so you will need to demo or research to see exactly what you are looking for.
Well-recommended desktop entry-level amp/dac combos include the Schiit Fulla amp/dac combo at $79, Schiit Magni & Modi combo (total $198), or the JDS/Mayflower Odac/O2 amp ($280ish). There are also usb-hub type dac options with limited amping power, most popular one being the Audioquest Dragonfly ($99 for v1; $129ish for v1.2) & other more expensive options from Meridan, Audioengine, HRT streamer off the top of my head (should be more options). Then there is the portable sub-$150 amp/dac category that primarily consists of products from Fiio. The older E07K and E17 are worth considering for value
rice along with their new release the E17K
If you want to get the EL-8, I personally feel that the wisest option is to simply get the open version for the best sound performance as they do seem too large for true portable usage unless you require noise isolation at home that the closed version will provide. Do keep in mind that at the $699 price point you are in the upper-upper end of mid-fi headphones. There are a variety of great options at & below that price point and you can even jump over to a flagship option on sale or open box at a very similar price point.
hope this information was helpful
