Zeleni Zec
Sponsor: Audeze
Purpose of MRI version is mainly communication with patient and noise suppression, not high quality music reproduction. Amplifier for it is custom made and definitely not satisfying any Hi-Fi standard regarding reproduction of low frequencies. I don't think that anyone buying headphones at TOTL level will trade bass for a little bit more dynamic range. I'm not talking about 20 Hz, it's more like anything bellow 150 - 200 Hz. For intelligibility bass is not needed and only make it worse. Noise suppression reduces available output level by the same amount with which noise is suppressed. If you want to reduce noise by 20 dB you have to sacrifice 20 dB from maximum output level.I remember someone from Audeze at Canjam mentioned that the MRI version of the CRBN has much greater dynamic range than the consumer model because they run on a much higher volt (1000v?) amp/system. If that’s true then what is it to stop the standard from moving beyond the Stax Pro Bias 580v standard?
Basically my (noob) question is whether this current standard is holding back the development of better consumer grade implementations with new amp technology?
If you want to cover full range from 20Hz to 20kHz, 580V bias gives you enough problems with sticking of diaphragm to one of the stators and increasing the bias voltage can only make it worse. Higher voltage is not trivial problem for amplifiers as well, parts are more expensive and not easily available. Audeze has no plans to go that way.
Stay updated on Audeze at their sponsor profile on Head-Fi.
