DeeKay10
- Dec 8, 2010
I've recently bought a pair of Shure SE535s, after previously having a pair of SE210s, which cable torn two years and a month from purchase (what an odd coincidence!).
Having not the greatest ear moulds in the world, I naturally needed to try a few sleeves. Thing is, you can't get them off, can't get them on, and so far I managed to destroy four of them - a pair of large and medium sleeves.
Now, it's not a new thing for Shure headphones to have tight sleeves. It took tremendous force back then, with the SE210s, to put on the sleeves, but the difference was that the base was made of hard rubber, so they could slide in as you twist them. With the SE535s however, they made the dumb decision to make the base out of softer, less-denser rubber, which simply gets stuck on the nozzle once you twist it in deep enough. The situation is so bad, that I ended up using so much force which not just made the foam come off the rubbery base (pathetically, you get accustomed to it after the first time you do it), but actually managed to tear the foam apart.
I later learned that you should expand the base of the sleeve before inserting it (and destroy the two factory-worn sleeves anyway), but it's still an idiotic solution which isn't suppose to be necessary in the first place, considering this is a $500 product.
I went to a local Shure distributer with the story, by the way, and they replaced the sleeves free of charge. When asked for an advice however, they suggest I'd lubricated the base of the sleeve before inserting it (quote: "try putting a bit of Vaseline in there before sliding them on"). I didn't know whether he was kidding with me or not. Eitherway, that's not gonna happen.
The question in mind, do all Shure latest in-ears (SExx5) suffer from this, or is it just me that got screwed?
