aamefford
I have a custom title!
- Nov 28, 2007
I finally completed the recable!!!!! A bit late, but I finally had a bit of undisturbed time. I used a 4 wire Litz flat braid with Navships' 24 AWG silver plated copper in teflon insulation. Note to self - next time, don't use 4 strands of white...
Pictures are posted in the DIY Cable Gallery, page 303, post #4544: http://www.head-fi.org/forums/f6/diy...ml#post5932552
I'll refrain from too much in the way of impressions right now, and update with an edit later - Why you ask?
Well, my Pico made a soft "whump" sound and quit working back in July. I mailed it to Justin at Headamp for repair. Justin's a busy guy, and only he knows when I'll get my beloved Pico back. That leaves me with a Macbook pro headphone out, a first gen. iPhone headphone out, and a second gen. flashcard modded iPod mini headphone out, and no amp, much less a DAC. Not much in the way of source / amp combos. Note that I find the Pico to be great, it competes well (betters?) the much loved Apogee Duet as a DAC / amp combo.
Anyway, lame sources, and no burn-in on the cable (ok, I don't actually buy burn in on cables, but noted for the record...). The brittle highs are finally gone, the bass is fuller and more controlled, the detail and clarity are impressive. The improved bass control is noticeable because previously without the Pico, the bass was full, but pretty sloppy. Sibilance is much improved - It is virtually gone on Diana Krall's "Girl In The Other Room." Sibilance is not eliminated, however - I still hear it in Sarah McGlachlan's "Mirror Ball."
I'll update later, when I have my Pico back, or access to another source and amp.
So far, these have REALLY responded to modification, and are a fine headphone. Now if I can just fix the chisel-like headband pad...
