FrameBit
- Apr 10, 2017
Stx ii - > rca - > jds o2 - > fidelio x2. Stock op amp.
I see
Hi I am using a STX 2 and I've noticed when I change the gain tuning setting for the headphone to the lowest one (IEM or for 16~32 ohms headsets), I hear a "click" sound. But it does not happen while selecting other gain settings. I think that click noise coming from a relay switch but what it actually does?
Thanks.
Also, I'm using a HD 700 so which op amps should I get?
Thanks.
Thanks.
I would recommend the Burson amp's that I used in my STX 2 they literally destroyed everything else I've used besides the conductor air I have. Fun facts I use the HD 700 as my primary headset also. That or the V6's. I can say for certain the V5-D's are amazing in the STX 2 they literally make it sing. However, when installing them it's important to make sure they are secured into the card with either zip ties or something to hold them to the sockets.
It’s difficult to say do you prefer absolute clarity or heavy warmth? The Vivid will provide the clearest audio experience, the classic while they are still fairly clear focus more on the warmth of instruments or so I’ve heard. I’ll have a Burson play with 5 V6 vivid coming in a few weeks. After that I can tell you first hand experience with them.Thanks for the suggestion. So which Burson op amps you are using?
Edit : Oh got this you are using the v5D's. So if i get the v6 which should I get vivid or classic?
By clarity did you mean bright? I'm sorry I'm very new to the audio terms. And please don't forget to share you experience with the v6 vivid. I'm looking forward to hearing from you.
Vivid should produce more detail and what I mean by clarity is the transparency of the sound and the separation of it. For an example, when paired with my HD 700 and those op-amp's the sound is so clear when I play FPS games that I can not only tell the general area a shot comes from but what gun it is from a considerable distance. Everything from every little detail is pronounced with the V5D (which is similar to the V6 Vivid) you can pick apart details in music as well. It's really incredible. Asking for the V6 classic I can't say I'd probably love them too because in orchestra pieces I imagine they shine really well.
Thanks for explanation. Yes now I'm sure I want clarity with good instrumental separation. So I better go with V6-D's. Now the question is if I only get 2 V6-D in I/V for the headphone out and left the buffer op amp to default with is Muses 8820 is there going to be any problem like I/V buffer voltage imbalance or some kind of overload while using the line out port?
Btw the V5 (I assume V6 also) makes the biggest impact when used on the buffer socket.
You meant the buffer affect only the line out port's (speaker output) audio quality right? Because as far as I know the STX II's headphone output only uses the two I/V slots.
