Cruxiaer
- Jun 15, 2016
It is yellow. Why?
There's another review somewhere that said the older batch with yellow glue sounded better than the newer batch with black glue (which is what I got).
It is yellow. Why?
My STX is all stock. I still wonder how much better would STX II be, if at all? Stock vs stock or upgraded opamps vs upgraded opamps. I've been reading head-fi forums for the last day about it, and saw no definitive answer.
Hi all,
Anyone here installed ASUS Essence STX II into Windows10/Dell XPS 8900 desktop PC?
As a wary novice (experience inside PC limited to adding RAM), I question two things that I read in the ASUS online installation instructions:
1. “STX requires a 4-pin Molex connection to power the card.”
Is factory-stock Dell XPS 8900 desktop PC not supplied with 4-pin Molex? Would I need to replace XPS 8900 power supply cord, or buy some type of adapter to go between the STX II and XPS 8900 power connectors?
2. “Front panel audio header: Connect to the chassis-mounted audio module.”
What are “front panel audio header” and “chassis-mounted audio module,” and where are they located on Dell XPS 8900?
Can anyone answer these questions before I buy ASUS Essence STX II (2-channel version)?
Thanks, much appreciated.
1: The molex connector is the one that is used for powering non-sata HDD/DVD devices.
There must be one available. But i cannot find the actual listing of available power connectors.
Take a look on what unused power connectors you have!
If it is a 4pins flat type
then you are good to go
2:
See: ps-8900-desktop_service manual (http://downloads.dell.com/manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-8900-desktop_service%20manual_en-us.pdf)
page 16 connector 21 or page 75
You don't wanna use the the frontpanel audio! You buy this card for the rear panel connections!
