Hello,
I previously owned a Xonar D2/PM and was very happy with it. Didn't use headphones before. But later I decided to buy a Sennheiser HD650. As the D2 would not be enough to feed the HD650, I decided to upgrade my soundcard and bought a STX II
However, I am not happy with it. The sound is muddy, not clean and warm enough. It is the same with headphones and speakers.
When I connect HD650 to my Note5 smartphone I am getting the clean and warm sound I am looking for. It sounds as it should be. I read lots of positive reviews before buying the STX II so I believe it should not sound so bad.
I have not changed anything except the soundcard, hardware or software wise. Using Jriver with asio as I used to.
Do you have any ideas what might be wrong?
Thanks.
