Have browsed through the thread, I haven't really seen anyone discuss what headphones they use\recommend with the STX II. I'm thinking of getting a new set, only using Bose QuietComfort at the moment just because that's the best I have. Using Tannoy 402 speakers most of the time, which is great. Just don't want to over spend on headphones. Sennheiser HD 650 or something? My sources are lossless and I mainly listen to music on the metal/prog spectrum.
Im using onkyo se-200 pci ltd. How STX II can compared with onkyo se-200 pci ltd in term of sound quality in RCA coaxial connection? I meaned RCA coaxial connection, not headphone connection.
Does it worth upgrade from onkyo se-200 pci ltd to STX II?
Thanks.
hi verde57,
Hard to say not sure of the mod you have done. I have ran an Auzentech Prelude, the STX, the ST and the STX II.
The STX I did not like ( might have been a bad card). The ST with the original clock correction I really liked, but read they were coming out with the STX II so went with that.
I really like the STX II.
Probably the best thing you could do is order one and if you don't like it, send it back.
Thanks for the observation. The Hot Rod gPC™ really wants a legacy PCI card for audio on the GA-MA78GM-S2HP given the design-optimization of ALSA snd-emu10k1 for the CA0102 and CA0108 rather than the CA10200 and CA10300, so, given emu10k1's tendency to lock up the system whenever hot-plugging the Creative Laboratories® SB1550, I've decided to either revert to a Creative SB0350 in good condition (I still have the SB0250 I/O Drive), or replace the SB1550 with an original XONAR® Essence™ ST. (I have the STX II under consideration for a re-equip of the Asus® CM1630, as it has all the capabilities of the original ST plus better clock stability and PCIe hookup.)
I am planning to get (in the future) an STX II and later on change the op-amps for better perfomance, but I'm having trouble to decide what op-amp change should I do:
I am using 3x V5 coupled with 3 SLIMIC II together with the MKP mod and can tell you that they sound AWESOME.
In my point of view there is a noticeable improvement in every possible aspect, but what I like best about them is the incredible clarity. I can hear every little micro detail in the song.
Currently I am using my STX 2 with the AKG 712 Pro, which couple quiet nicely.
I will upgrade to some end game headphones soon though.
"I am using 3x V5 coupled with 3 SLIMIC II together with the MKP mod and can tell you that they sound AWESOME."
Is there any place i can ready about how to upgrade this card into these specifics?
Looking for improvement for my stereo machine and Denon D7000 headphones
