MaxD
- May 7, 2012
Dow Dow, Im not so bright some days... Thanks.Not yet, it is the middle of the night in Korea. I am in the US and just saw this post this morning my time, which is nighttime in Korea.
For microSD card, we recommend FAT32 for best results. You can format microSD cards as FAT32 from the player itself by going to Settings -> System information -> Erase SD card.
For the external drive, exFAT should be fine. My 1TB portable drive is formatted as NTFS and I haven't had any issues with any of the players recognizing it.
Hi All!
Looking to replace my Sony WM1A with something that can stream. Until now I held back mainly because of the battery life but the SR25 looks solid in this regard.
Now, has anyone had both and can share a comparison between the two?
Greatly appreciated, thanks!
Thanks! I also had the ZX-507 and had to return it - EU version volume cap was abysmal. And battery life with all optimisations was quite bad as well.I went from the WM1A to the ZX-507 but couldn't handle the battery difference. Picked the SR25 up after release and I'm amazed at the battery life for a well made streaming capable DAP.
Hi All!
I had ZX300 and WM1A, and then WM1Z (which I ended up with).
There are fewer differences between them than between any of them and the SR25.
The SR25 has a normal low bass, but the mid bass is less than that of Sony, as a result the sound is more subtle, that is, it lacks a “body”. At the same time, the middle is more emphasized, as a result of something like folk and jazz it sounds very beautiful, but rock / pop / metal is more interesting to listen to on Sony, especially if these are old records of the 70-90s.
We do not currently support the Shure app.Jason, will the open app support the Shure AONIC 50 app? I didn't see it on supported apps. haven't had the time to look fully yet.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Hi All!
Thanks for the details... I might like the Sony better according to this I really do like how the 1A sounds, but the grass is always greener...
Nice photo! Are those inEars?
Is the interface more fluid than let's say the SP1000M (which I had for testing at some point)? Compared to the Sony WM series all previous AK players felt sluggish.
Planning on picking up an SR25 this Friday, one last question in my mind is it possible to replace the battery in future?
Great to read all the positive reports on batter life per charge cycle, but it will degrade eventually.
thanks!
The SR25 is not Roon compatible
