Astell&Kern new flagship A&Ultima SP2000
Jun 20, 2020 at 3:22 PM Post #3,406 of 5,840
Latest Qobuz update.
I installled v5.9.0.2 on Thursday with about 70GB of 'imported' (to use Qobuz terminology) music on my SP2000. The stuttering seems to be fixed and I didn't experience any major performance issues although the app is always quite laggy. But it was generally useable. Emboldened by this, I started to import more of my favourited releases. Things were going ok until I got to about 175GB of downloads. Then I got my first freeze again during download. Followed by two more. Doesn't seem to make any difference how many tracks you try to download in one go. Performance has become a little slower in loading. It's still useable and I haven't as yet had any more stutterings, but this seems to be about the limit the app and/or device can cope with whilst maintaining response times that I can just about live with. The Offline Library takes about 1 minute, 5 seconds to load, rather annoyingly every time you click out and then back into it. Also for some reason, accessing the same imported release from the Offline Liibrary seems to be significantly slower than from My Qobuz - My Favourites. It takes about 15 seconds for a release to open when selected from the Offline Library list as opposed to no more than 2 seconds to open from My Favourites. I now have 184GB of imported music but I am assuming that if I import any more releases the situation will only get worse leading to the same complete meltdown experience I had with v5.8.0.1. I would actually like to listen to some music!
I was able to work out that the first version of Qobuz I ever loaded onto my SP2000 was v5.4.3 where this problem also existed more or less the same. It has existed in every version that I have loaded since then, although I have skipped a few versions so haven't tried every one.
@JasonNYC What is the best way to formally log this as an issue with Astell & Kern? I plan to raise it with Qobuz as well but it would be good if someone could take ownership of the problem so the reason for this can be determined and hopefully find a solution. If there is no immediate solution, an honest appraisal of the limitations of Qobuz on Astell & Kern devices should be established and admitted to.
Many thanks
Steve
Jun 20, 2020 at 6:57 PM Post #3,407 of 5,840
Many thanks
Steve
this sounds more and more like an algorithm issue with however Qobuz is indexing the tracks and/or doing file io and directory management. they probably assumed Android == phone == 64 or 128GB max downloads and eh... it’ll work. I’d be curious if their desktop app showed the same behavior and if not then I’ve got a pretty good guess at what didnt get ported to the mobile app. As far as reporting to them was there a linear slowdown after a certain point and then every so often say 50 or 100 more tracks something measurable in seconds and if you remove some download is it a linear speed up? that sort of info would at least point the devs towards a O(n) sort of file scanning problem or file growth problem (I’m taking a few guesses not having used the app but having run into this with my own programs), if they don’t know already, and then mention just how many 100’s of GB and number of tracks you’re trying to download because frankly it doesn’t look like they tested very high and the way to fix this for 512GB should hold for 1TB or more too.
Jun 24, 2020 at 5:54 AM Post #3,408 of 5,840
How are people's CU models holding up. I have some very slight tarnishing now that seems to reduce by rubbing with a microfiber cloth. It's nothing like an AK380. Its odd as its mostly on the back which has been in the AK case the entire time and not touched by human hands at all
Jun 24, 2020 at 6:41 AM Post #3,409 of 5,840
You did not apply the back protectors? I applied the protector since I had the player as the back is a fingerprint magnet. Mine is fine with the plastic cover.
Jun 24, 2020 at 7:23 AM Post #3,411 of 5,840
No issues here. I like using this clear TPU case over the leather versions, so you can see the beautiful colors of this thing.
Jun 24, 2020 at 4:35 PM Post #3,413 of 5,840
If anyone is looking for DSD512 content for their SP2000, NativeDSD.com is giving AK owners 20% off the new Positive Feedback DSD Sampler Volume 3. It is available in all DSD rates including DSD512.
David Robinson, editor in chief of the audio review site Positive Feedback created the Positive Feedback DSD Sampler Volume 3 with selections from the following 6 albums:
Bach: Harpsichord Works (Sono Luminus), Mabuchi Plays Miles Davis (Yarlung Records), Prokofiev: Alexander Nevsky / Lieutenant Kijé Suite (Reference Recordings), Reid (TRPTK), Bach: 6 Flute Sonatas (OUR Recordings), and Beethoven: Symphonies Nos. 1 and 5 (Channel Classics)
Get 20% off with coupon code AKVOL3. Coupon code expires July 1, 2020. Link to album - https://www.nativedsd.com/albums/NDSD016-positive-feedback-dsd-sampler-volume-3
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Jul 2, 2020 at 10:02 AM Post #3,414 of 5,840
I'm really enjoying my SP2000, but if there's one thing I find off with this generation of AK flagships it's the leather cases. Sp1000 got much prettier, more vibrant Cordoba greens and reds, all kinds of cases. I have the black sp2000 case and the green that came with SS, and both are quite muted and conservative.
Then, one would assume, you go to aftermarket leatherworks, right?
Well, Valentinum doesn't have an sp2000 to measure so they don't make one. (They made nice cases for sp1000, but don't have an sp2000 on hand to measure so they don't make those.)
And the cases Dignis makes for sp2000 are just way ugly.
So this is my call to Astell & Kern -- please put more cases on sale! The red from the black onyx one would be cool -- but also new ones! This would be very appreciated!
Proof?
This is the choice ak120 owners got 7 years ago: https://us.astellnkern.com/products/ak120-ii-case
This is what sp1000 owners got 2 years ago (scroll down a notch): https://us.astellnkern.com/collections/accessories/products/sp1000-standard-leather-case
This is what sp1000 owners get today: https://us.astellnkern.com/collections/accessories/products/sp2000-leather-case
Jul 2, 2020 at 4:36 PM Post #3,415 of 5,840
I favor the clear tpu case, but I also have a leather case from China.. But yeah, also there the colors are limited to black and brown. Suits me just fine, I like bleak colors, must be my personality. :beyersmile:
Jul 3, 2020 at 5:09 PM Post #3,419 of 5,840
The SP has one year, the convert chips are tops the amp arquiteture is very advanced, and, has every top dap from AK has one of the lowest noise level, I should remember you that all the "evolutions" that you claim in the recent DAPs there is one thing that until today no one done, if you pay attention the tops daps from AK have no low gain no mid gain or high gain, and even without that factor (that "help") the noise is very very low, don't you think that to achieve this it took a lot of work and the use the highest quality components? The sound is subjective, people can like, others love, others hate it,not even God pleases everyone, but the rest is not questionable
Jul 4, 2020 at 3:57 PM Post #3,420 of 5,840
The strategy is having the best sounding Dap, expensive (is not for everyone) with minimal EQ (don't need) and a 2.5mm that the only let down is that is more fragile than the 4.4 IMO
IMO, nothing quite sounds like the SP2K. It allows me to dig deeper into the music. The next upgrade for the 2K will most likely be the 3K next year. I’m anxious to see what they’ll implement.
