Terry Newton
You're welcome.I had no problem with the company and was in touch with the person who made the cable.Friendly and fast.
I always feel DAP works best what its made for. Any extra features like wifi bluetooth or streaming services hinder the performance of the DAP and it is basically a manufacturers tool to sell the product and attract more clientele.there are bugs..i use MOOV streaming and its constantly give me warning WIFI signal not strong even though i am sitting next to the AP
For those who have subscribed to Tidal HiFi, how good and reliable is the service on a Kann? Tidal HiFi is quite good on my iPhones and a Onkyo DP-X1A but on some DAPs I have tried it's not very reliable.
Thanks
I would second surfcables, I have a balanced cable for my AudioQuest Nighthawks and the combination of the Nighthawk, Kann, Surf balanced cable just might be end-game for me.Who sells good balanced cables for use with Sennheiser HD 800 headphones and the KANN?
I have purchased a couple of cables from them and agree with others. Their service and products are great.Sounds like what I am looking for and know Surf is a good company. Thanks!
How did you get to the secret menu and how does it help.Kann secret menu
If you keep the Kann face down the rear of the kann aluminum body acts as heat sink and it does not heat up much. So far I have had no issues. CheersCould be...but my guess is the amp. When left turned on but idle, the temperature dropped and stabilises. This sucker definitely need a good heatsink
I run them high gain on balanced out, volume around 70-ish.
Will bring back my infrared thermometer next week and measure the temp on the casing...not good tbh
Mojo has larger soundstage and is more bright. Kann is warm but mojo is well balanced.KANN better sound than MOJO?
I do have similar issue. The android file transfer does not play well with the kann.Mac users, does anybody have trouble to connect to Android File Transfer? In Kann's settings MTP checked but in drop down menu it switched to DAC. For AFT to recognise the Kann, I have to restart the Kann with usb cable connected. AFT won't see the player, if I disconnect the cable and connect it again. I am wondering if it's software glitch or I can fix it myself. Any thoughts?
