T.W.G
- Oct 18, 2005
Ah, thank you very much! Will search and install it.
I can’t seem to find a firmware update for KANN on the A&k website. Until now I’ve not looked for another one since the aborted update that apparently bricked some people’s units.There was a firmware update to fix this issue months ago. I assume you are not on the latest firmware.
There should have been one available OTA, it would not be available on the AK website to manually install. Let me check back with the team and confirm.I can’t seem to find a firmware update for KANN on the A&k website. Until now I’ve not looked for another one since the aborted update that apparently bricked some people’s units.
Has there ever been a further update?
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Ah, I’ve not tried OTA on my KANN. Is it now safe to do so?There should have been one available OTA, it would not be available on the AK website to manually install. Let me check back with the team and confirm.
How to use AK connect on Kann? I have installed it on my phone and Kann does not appear. Both are on the same wifi network.I am using two ways when I want to listen to Qobuz on Kann (which I also find tube-like)
1. Using Kann as USB-DAC out of either desktop or laptop computer, or from smartphone. It needs a usb cable to the micro-usb slot. (From smartphone it has to be USB-C to micro usb OTG cable)
2. Using AK connect service on Kann, playing Qobuz from BubbleUpnp on android smartphone, or from mconnect app on iPhone to Kann. I found mconnect more stable and more comfortable than BubbleUpnp. I think both app support tidal as well. This methods needs wlan, but works even on smartphone hotspot.
Swipe down from the top of the screen of the KANN. Tap on the nut sign to get into settings. Tap on "AK CONNECT" to get in the "AK CONNECT" menu. Tap on the white dot right to the lower "AK CONNECT" text. The dot gets shiny white, "AK CONNECT enabled" text appears on the lower part on the screen for a short time.How to use AK connect on Kann? I have installed it on my phone and Kann does not appear. Both are on the same wifi network.
I leave "Sleep mode" off for convenience.
Now when you start the "AK connect" app on your phone you can tap on the tree lines in the top left corner to get the menu. Tap on the small down arrow next to "SPEAKER" to see the available renderers. "KANN" shall appear under the "My Device : here is your phone name".
In the "LIBRARY" menu you can choose the source of the music. Tidal seems to be here a possibility, but I cannot test it as I do not have Tidal subscription.
BubbleUPnP works in a very similar manner, that includes Qobuz as source.
Make sure that the KANN is close enough to the wireless router to get most of the bars on the WLAN icon. That makes the songs start faster - do not expect miracles, 5-10 second delay is "normal".
You are welcome.Thank you so much for the information! I got it on the first try. I didn't think it would be that easy.
What is better for you? Qobuz or Tidal? I don't know Qobuz.
Just one question. Is there a way to use Spotify? I have a subscription right now and I'd like to use it.
Thank you so much
Thanks again for the info.You are welcome.
I trialled Tidal when they were still pushing MQA. I compared, I found Qobuz better sounding, stayed there and have not looked at Tidal any more.
For Spotify I have not found any other method than using KANN as USB dac from computer or android phone.
I have Spotify because of the different content and family use. I use it only when something is not available on Qobuz.
You can't even update todays date. KANN ends at 2023So it's not possible to update the firmware to get Spotify inside Kann?
