thecrow
- Oct 18, 2014
So without the case is there many dramas with bluetooth or is all pretty good? How long have you now been using it without the case in that regard?Yes, see a few posts back. I have the Shure BT headset and use it with my andromeda’s sometimes. At first they were pretty much useless until we discovered the problem with the case. The leather case blocks out a huge amount of both wifi and bluetooth, but without the case its really quite good. I was getting about 8 metres range with aptX HD and I’ve also used it with A2DP on my helmet headset, it worked ok (better than the aptX HD) before I found out about the case so I’m sure it would be much better without the case too.
I think its the moisture content - bluetooth won’t transmit through water. Google say leather is around 10% compared to plastic at 2%, so a plastic case would probably be much better even though it would look terrible.
Cheers
