Sep 21, 2019 at 9:37 PM Post #1,036 of 2,255
Hi, how do you like the Solaris with Kann cube? My Solaris is on the way. Is the hiss you hear from Solaris with the cube really a problem? Thanks!
I liked Solaris more then Andro, they are one of the best IEM i listened to, but for me a bit too much punch in the sound, I like them warmer . Kann is an amazing Dap very analytical close to 0 distortion so they will make your Solaris sound great. I think I would prefer a more warmer Dap sound like SP 2000 or Onkyo Dp-X1 but I think you shouldn’t worry, Cube and Solaris are both stato of the art.
I wait for your opinion.
Sep 21, 2019 at 11:05 PM Post #1,037 of 2,255
Thanks for sharing your idea! I'll test it once both my Cube and Solaris arrive.
Sep 22, 2019 at 7:08 AM Post #1,039 of 2,255
SO
Wifi connectivity with the Cube is SO BAD with case on as to consider a defect.
I may return due to this.
Yes, wifi and bluetooth both really bad with case on....bit of a problem for such a nice case, maybe a plastic case might help...lol jkr
Also, I’ve also noticed my volume knob is a bit stiff/crunchy at times, its a bit like there’s grit caught between the knob and the body but there isn’t. I think it might be internal but it all works at this stage.
Sep 22, 2019 at 7:21 AM Post #1,040 of 2,255
when asking my local dealer about daps and bluetooth feature he did mention the cube's bluetooth has some issues. From what i gathered if you cover the top that may have something to do with it but i doubt it can be as simple as that
So from that even though it may be a future purchase for me, when it comes to my sony mx3's and b&o h9i then my phone will be the main source for bluetooth....and though not perfect I can live with it as a compromise/limitation
(the kann cube sounds so much better than the fiio m11 and ibasso dx220 for me)
also wondering how good is the cube as a dac only as part of a desktop system. I have read here it is not as detailed as the hugo 2 but if there are other opinions / comaprisons that would be great
cheers
Sep 22, 2019 at 10:02 AM Post #1,041 of 2,255
cheers
I have them both and I use Hugo 2 especially because the Cube used even in desktop mode doesn’t have more then 7 hours 25 min of battery even on mid-gain amp ( or I don’t know myself how to use it but is plugged with original cable on a USB 3 port)
The sound differences are not so big, yes Hugo 2 is more detailed a bit on the open sound style more analytical and has the filtering options and the crossfeed,but The Cube is so direct and so close to perfection for a Dap, impressive at high volumes, not warm but not cold,and at the same level with Hugo 2 just different.
I could just live with the Cube in no need of another DAC-amp if needed is that good.
Just the battery issue.
Sep 22, 2019 at 10:50 AM Post #1,042 of 2,255
Can't you use the DAP while charging?
Sep 22, 2019 at 1:42 PM Post #1,044 of 2,255
While using it as a DAP yes, while using it as an external DAC like he is, no.
Edit: that's why the original KANN had two USB ports; one for data/charge and one for audio. CUBE has just one and can only do one or the other at one time.
Thanks...sorry I didn't realize what he was doing. Obviously, if there is only one USB port you couldn't do that. Sorry I didn't read. I have only used mine as a DAP.
Sep 23, 2019 at 4:04 AM Post #1,045 of 2,255
My one has the same issue. I am pretty sure it was not there at the beginnig. It was such a bad feeling first noticing it. Like the perfection has gone. Fortunately just cosmetics so far.
Sep 23, 2019 at 1:54 PM Post #1,046 of 2,255
Using the AK Ripper MK2 w Cube and ripping is going smoothly except, the Gracenote db is returning the names of album and track but not the cover art. Is anyone having this issue? I am ripping to FLAC.
Sep 23, 2019 at 8:17 PM Post #1,048 of 2,255
Ok Seems to be a gracenote issue ...some CD are returning artwork ..the more obscure ones aren't.
Do the lyrics come through? I should be ready to use the ripper with my cube very soon. I’m sure there will be a steep learning curve just like I suffered with monkey media, but once setup I’ve been told it works well
Sep 23, 2019 at 10:54 PM Post #1,049 of 2,255
I got my Kann cube and Solaris. I'm using the stock 3.5mm unbalanced cable. I didn't get too much impression, but I can see some drawbacks.
1. Wifi is only at 2.4GHz, the wifi is slow. It may take a while to load the music on Amazon Music app.
2. Battery should be better.
3. It's getting warm very quickly...
4. If you can't make a bigger battery, would you make a quicker charger?...
