May 13, 2019 at 3:31 PM Post #91 of 2,255
Sorry, forgot to include pics. This is the SP1000 AMP case, which is similar to KANN CUBE case with the same back.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
May 13, 2019 at 6:58 PM Post #92 of 2,255
Yes, KANN CUBE includes a leather case in the retail box. It's similar to the case for the SP1000 AMP. I thought I took some pics of it, but can't find it in the moment. Below are the pics of the SP1000 case. The KANN CUBE has a similar design on the back.
And have it included 5-pin mini xlr to 2-3pins xlr cable?
May 13, 2019 at 7:10 PM Post #93 of 2,255
@JasonNYC
Same question, do i find this cable in the box??
Or if it’s not...where do i find one?
The USB mode to use with a external DAC, is the same as the KANN?
May 21, 2019 at 5:40 PM Post #96 of 2,255
May 22, 2019 at 4:25 AM Post #98 of 2,255
Recently, there is like a wave of people , or negative people to just bash and negatively posting about the modern high-end gears. I have seen across this forum and others. But if you check those guys out, they are new posters, and don’t even have much experiences in technical or listening at all.
Anyways, I doubt the SE100 can drive headphones full-size as well as Cube. The power output is crazy
May 22, 2019 at 5:02 AM Post #99 of 2,255
I know I was negative in the beginning but both Cube and SP2000 are pretty interesting, as, as I understand these are the first DAPs to use current output mode. I thought ES90X8PRO only uses current output mode, but looking at the product info they so support both voltage and current output and they achieve their bests (better THD, DNR, and what else?) in current output mode. I guess all existing DAPs with these chipsets are using voltage output mode. It would be great to have a DAP that can deliver the performance of a full blown desktop setup. I am dying to hear those beasts now.
May 22, 2019 at 5:18 AM Post #100 of 2,255
I know I was negative in the beginning but both Cube and SP2000 are pretty interesting, as, as I understand these are the first DAPs to use current output mode. I thought ES90X8PRO only uses current output mode, but looking at the product info they so support both voltage and current output and they achieve their bests (better THD, and what else?) in current output mode. I guess all existing DAPs with these chipsets are using voltage output mode. It would be great to have a DAP that can deliver the performance of a full blown desktop setup. I am dying to hear those beasts now.
Maybe at first you were trying not to like it, so you wont end up buying another dap.
May 22, 2019 at 5:21 AM Post #101 of 2,255
I will keep it short, but th emote you are looking and finding facts about these portable and digital music.....you will arrive at Sony DMP-Z1 ....LOL!
I have seen it somewhere ;)
May 31, 2019 at 5:02 AM Post #102 of 2,255
Beside all tech issues with SD card, 2.5mm balanced etc - can anybody share some thoughts on listening?
I would love to find some comparsion with Hugo2. This looks like powered enough to replace hugo2 for sound and usabiity as DAP.
May 31, 2019 at 6:44 AM Post #103 of 2,255
Any kind of impressions would be good, actually. I would be interested to hear impressions for vs SP1000 / vs Hugo2 / vs N8 / vs DX220 etc.
May 31, 2019 at 6:51 AM Post #104 of 2,255
And sp2000
May 31, 2019 at 7:14 AM Post #105 of 2,255
And sp2000
These don't mean much maybe, as the differences written here need bat ears to hear them. By the way, one of the questions I had was whether Cube is making use of all channels of the ES9038PROs, and according to the A&K website, yes it is. So, 8 channels in mono mode per side driven in current mode.
SP2000 Audio Performance
Frequency Response
±0.015dB (Condition: 20Hz~20kHz) Unbalance / ±0.010dB (Condition: 20Hz~20kHz) Balance
±0.050dB (Condition: 20Hz~70kHz) Unbalance / ±0.030dB (Condition: 20Hz~70kHz) Balance
Signal to Noise Ratio 124dB @ 1kHz, Unbalance / 125dB @ 1kHz, Balance
Crosstalk -138dB @ 1kHz, Unbalance / -144dB @ 1kHz, Balance
THD+N 0.0005% @ 1kHz, Unbalance / 0.0004% @ 1kHz, Balance
IMD SMPTE 0.0003% 800Hz 10kHz(4:1) Unbalance & Balance
Output Impedance Balanced out 2.5mm (1ohm) / PHONES 3.5mm (1.5ohm)
Clock Jitter 25ps(Typ)
Reference Clock Jitter 200 Femto Seconds
KANN Cube Audio Performance
Frequency Response [Phone Out]
±0.027dB (Condition : 20Hz~20kHz) Unbalance / ±0.025dB (Condition : 20Hz~20kHz) Balance
±0.070dB (Condition : 10Hz~70kHz) Unbalance / ±0.087dB (Condition : 10Hz~70kHz) Balance
Signal to Noise Ratio [Phone Out] 117dB @ 1kHz, Unbalance / 117dB @ 1kHz, Balance
Crosstalk [Phone Out] 129dB @ 1kHz, Unbalance / 136dB @ 1kHz, Balance
THD+N [Phone Out] 0.0004% @ 1kHz, Unbalance / 0.0005% @ 1kHz, Balance
IMD SMPTE [Phone Out] 0.0005% 800Hz 10kHz(4:1) Unbalance / 0.0006% 800Hz 10kHz(4:1) Balance
Output Impedance PHONES 3.5mm (1.2ohm) / Balanced out 2.5mm (1.6ohm)
Reference Clock Jitter 250 Femto Seconds
