gordec
- Aug 14, 2006
Anyone using the Cube with Westone W60 or W80? I have ES60 which is very sensitive. I can't stand any hiss or any audible noise level.
I think it will be at least $ 3,000. However, as always... Well them to hell.The new Layla Aion look quite nice. 12 drivers in each ear. Anyone want to speculate on the price?
.... and there he was again the white frame. 5 tracks heard, volume 50, low amplifier, headphones Focal Elegia. Any news?Thanks for the pic. It looks like you are in the US. I assume you reached out to our US support team and they are the ones helping you? If so, I will follow up with our head of US support to get an update and I will also follow up with you @Silbersurfer once I have the info.
Am i right to assume this is no longer in the box from what i now have seen?Sorry, forgot to include pics. This is the SP1000 AMP case, which is similar to KANN CUBE case with the same back.
Low gain 50 volume i can barely hear at 60 volume on an iem i just did a hearing test too i had perfectly fine hearing.
Or should I better contact my dealer for an exchange?
sent you a PM.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
KANN CUBE does not come with a case. It is a separate purchase.Am i right to assume this is no longer in the box from what i now have seen?
Depends on what IEM you’re using and how sensitive it is. For EE Phantom I listen between 40-50 on low gain. EE Legend X I’m between 60-70 on low gain for roughly the same volume level.Low gain 50 volume i can barely hear at 60 volume on an iem i just did a hearing test too i had perfectly fine hearing.
Listen to the Focal Elegia with 50 Volume, and Mr. Speakers Aeon with 65 Volume. ....and i did a hearing test last week tooLow gain 50 volume i can barely hear at 60 volume on an iem i just did a hearing test too i had perfectly fine hearing.
I use balance and i listen around 85-125 low gain with Sony ier z1r and 10 volume lower overall with okko oh10Depends on what IEM you’re using and how sensitive it is. For EE Phantom I listen between 40-50 on low gain. EE Legend X I’m between 60-70 on low gain for roughly the same volume level.
Edit: Also whether or not you’re using balanced or SE output.
Could you answer my direct questions please ?KANN CUBE does not come with a case. It is a separate purchase.
@wazzupi Sorry, I don't have a PM from you and didn't see me tagged in any post from you. I will look back through the thread when I have a chance to get in front of a computer. As it is the weekend, I'm not in front of one now.Could you answer my direct questions please ?
