Astell & Kern AK70 MKII with dual DAC
Oct 27, 2017 at 12:09 PM Post #347 of 1,058
Nope, you need to Apply yourself, its included inside accessories box.
I know there are several in the box - I just thought they may be spares - I know Fiio used to pre-apply them.
Oct 28, 2017 at 3:46 PM Post #350 of 1,058
tried mk2 at the astell&kern shop today. i tested the first one for a week.
mk2 seems to have a darker tone compared to mk1. it resembled kann to me. mk1 had slightly thin vocal but looks like mk2 solved that.
although mk2 sounded like it has smaller soundstage than the mk1. or more intimate presentation.
just my two cents.
Oct 28, 2017 at 9:43 PM Post #352 of 1,058
Can i install external Android streaming apps, apart from tidal??
Although AK players run a customized version of Android, you cannot install apps to the player. There is no Google Play Store access and you cannot sideload apps. Tidal is pre-installed on the players.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Oct 29, 2017 at 12:03 AM Post #353 of 1,058
You also cannot save Tidal tracks offline as well making it a deal breaker across many ak players
Oct 29, 2017 at 4:05 AM Post #354 of 1,058
For anyone upgrading from the mk1 using Bluetooth I can confirm it is significantly improved in the mk2 with none of the dropouts I previously was experiencing.
Oct 30, 2017 at 8:07 AM Post #356 of 1,058
Oct 30, 2017 at 10:39 AM Post #358 of 1,058
somebody compares the AK70 MK2 to the old AK120??
maybe the black color of this edition was made to honor the old look of the AK120...
How this player can compare in sound and warmish of this sound to the AK120??
Regards
Oct 30, 2017 at 5:43 PM Post #359 of 1,058
Not too many reviews out there for this, I’ve sacrificed my chord mojo/s8 setup for this as I wanted a cleaner solution for portability. Was considering a mojo/poly setup but it just seemed too awkward a setup. I hope this has the ooomph of the mojo as well as a comparable sound signature
So, how do you like Ak70 mkii vs your previous Mojo combo? Thanks.
Oct 31, 2017 at 9:24 AM Post #360 of 1,058
OK so I just got my AK70 mkII and i have a question; Is it just me or does it take an age to charge - mine has taken half an hour to add 2%, does this sound like a faulty unit?
EDIT: Just switched wifi and BT off which has helped a lot.
