harmonix
- Jun 13, 2009
My 380 is undergoing burn-in at the moment - whatever that actually means. Out of the box observations:
The larger display is worth it alone for me - improved layout and a joy to use. Found the 240 too fiddly and impractical for searches etc. Navigation is quick and slick and the layout of the menus has been improved. There is also an album tiling feature allowing very quick visual navigation of your collection via clipart (3x4 on screen at any one time).
The LCD display is black when switched off (versus grey on the OLED) - but contrast when on isn't quite as good - but hard to notice unless you do a side by side. Colour temp is noticeably cooler though on the 380
The micro-sd slot is very fiddly on the 380 - likely because its out edge is at an angle. Took me literally 1 minute to seat the card successfully.
The new case is shiny and brown - not such a big fan - but the fit is immaculate as we have come to expect
Volume calibration is different and threw me at first. Comfortable listening for me is around 85 to 100 whereas on the 240 it was 45 to 55. Max level increases from 75 (240) to 150 (380).
Sound Q ? Well out of the box, I struggled to hear a difference between the 380 and 240 on DSD and ie800s and Laylas (a new set also burning in). Will perform a more critical comparison this weekend.
So the 380 is lcd vs oled on the 240? That's a step backward... besides oled should be absolutely black due to absence of backlight..sure it's not the reverse?
SQ sounds disappointing but will wait until you run it in... IMHO you tend to hear the main character early and gets better (or from good to better and not bad to good...)
