onlychild
- Jan 24, 2008
Are you feeding the WA8 from the Ak Amp output?
I know it's double amping, but I personally think it sounds much better when I feed my CDM from the amp output vs the AK380 headphone out. I set the amp on low gain using the balanced out so the max it will output is 2.1v at max volume.
Would love to get other's thoughts on using the attachable AK amp to drive other amps.
Sorry, not trying to start a debate on double amping. My thought process is that the headphone outputs a 2.1v signal, but the amp on low gain does the same but the signal is better, (deeper/tighter bass, wider soundstage, etc) so why not use that output to feed the CDM.
